RangerVol
- Thread starter
- #1
I picked up a Radioditty DB-25D the other day since they had a 20% off Black Friday sale. I didn't want to spend a ton of money on a radio because I don't do a lot of rag chew also our repeater doesn't really get busy until a Skywarn net is activated. It also does DMR so I can use my hotspot or the local DMR repeater for that
https://www.radioddity.com/collections/business-radios-mobile-radios/products/radioddity-db25d
It only does 20W on high, 5W on low, that's all the power I really need for working repeaters locally.
It only comes with a power cord that plugs into the 12V cigarette lighter port and has a 10A fuse according to the manual.
Only the positive has a fuse, the picture in the link makes it look like both +/- are fused. I haven't opened up the plug head to see if there's a fuse in there also
Do you guys think there would be any issues just plugging it into the cigarette lighter port with the radio and transmitting at 20W?
Also is that 12V port hot all the time or only when the engine is on?
I bought a Comet trunk lip NMO mount and a Comet Antennas SS-680SBNMO. Did a test fit, plan to mount it passenger side hood and it'll be perfect there. Just got to get the antenna wire inside, think I'll use the wire grommet that's behind the coolant reservoir.
