Grinding sound when turning right
egoboost
Austin
Illinois
2019 Ranger STX
Mechanical Engineer
I noticed a metallic grinding noise only when driving forwards and it's intermittent when going straight, but happens constantly when turning right. Doesn't seem to be in time with the wheel rotating. Anybody had an issue with a rock stuck in between the rotor and dust shield or something rubbing?
Racerdave6
Shorewood IL
2019 Ranger STX. 2017 Escape SE
Mechanic
Check your cv boots. Sounds like possibly a bad cv.
egoboost
egoboost
Austin
Illinois
2019 Ranger STX
Mechanical Engineer
From what I can tell both boots are still in tact and the grease hasn't dumped out. Could be that the joint went bad though.
Hi Austin,
Check the dust plate behind the right front brake rotor, There might be a slight contact causing this problem, if not a bad CV. Did you lift your truck? Some have had the CV come apart and sometimes things do not go right on reassembly due to the snap ring getting into the CV.
Good Luck!
Ranger Roger
Roger
Dagsboro, DE
2015 Honda Fit, 2004 Honda ST1300abs, 2018 Honda HR-V
Had this happen to my Honda HRV. Wife went thru large puddle. 3 rocks got lodged between bottom of motor and frame. Going in reverse knocked one out. Had to pry out 2 others. Terrible noise. Initial guess was in brake system.
Mooresville NC
2020 XLT FX2
Security System Tech
When I installed my leveling kit I bent the rotor dust cover to where it just barely touched the rotor. Only heard the noise when turning right. I simply bent it back out a little and the noise was gone.
