FYI: Headlight Adjustment After Lift
Discussion in 'Suspension / Chassis' started by Dennis Harvey, May 7, 2019.
  1. Dennis Harvey
    Dennis Harvey Active Member
    First Name:
    Vehicle(s):
    2019 Ford Ranger XLT FX4
    Apr 22, 2019
    Northern Virginia
    Msfitoy likes this.
  2. toddiscdn
    toddiscdn Well-Known Member
    First Name:
    Todd
    Vehicle(s):
    2019 Ranger Lariat 4X4
    Nov 2, 2018
    Blue Point, Ontario, Canada
    379
    317
    There is a 8mm bolt behind the headlight to move it up and down, its close to the fender side and adjusts quite easy. Thats on my Lariat, but I dont think there is any difference.
    I didnt have the luxury of a flat surface , so I made a note and took a pic of how they shone on the garage door before the level and got them in that general area after. I have since made a couple small adjustments on a dark quiet road on my way to work in the morning.
    Dennis Harvey and ulev1st like this.
  3. OP
    Dennis Harvey
    First Name:
    Vehicle(s):
    Apr 22, 2019
    Northern Virginia
    I have a XLT with halogen headlights. After a 2.5 leveling kit it took about 20 turns (clockwise) to get headlights back to where I shouldn’t get flashed by every car I pass.
    Rick - Saber and skibuff like this.
  4. Hack_Actual
    Hack_Actual Well-Known Member
    First Name:
    Justin
    Vehicle(s):
    2019 Ford Ranger Lariat FX4
    Jul 18, 2019
    Oklahoma
    231
    180
    For clarification purposes for anyone that may come across this as I did. The 8mm bolt, at least on the Lariat, has a spot at the top for a Phillips head screwdriver. The washer is toothed and adjustment is as simple as turning the screwdriver; I’d suggest a fatter head.
    Sabasigh, MTB-BRUH and Lunchbox88 like this.
  5. Lunchbox88
    Lunchbox88 Well-Known Member
    First Name:
    Logan
    Vehicle(s):
    2019 Ranger SuperCrew FX4
    Jun 21, 2019
    Missouri, USA
    280
    182
    Thanks for the follow-up, Im sure this will come in handy for people.
  6. South Florida Ranger
    South Florida Ranger Well-Known Member
    First Name:
    Vehicle(s):
    2019 Ranger FX4
    May 12, 2019
    Hollywood, FL
    103
    200
  7. joeb427
    joeb427 Well-Known Member
    First Name:
    Vehicle(s):
    Feb 11, 2019
    983
    1,156
    Occupation:
    Garage Profiles:
    I'm trying to do it in the garage close to a wall. I lowered both sides about two inches using a small wrench that took forever.
    How much higher should the passenger side be compared to the driver's side?
  8. Hack_Actual
    First Name:
    Justin
    Vehicle(s):
    Jul 18, 2019
    Oklahoma
    231
    180
    They should be level.
    Rp930 likes this.
  9. joeb427
    First Name:
    Vehicle(s):
    Feb 11, 2019
    983
    1,156
    Occupation:
    Garage Profiles:
    Usually, the driver's side is lower for oncoming traffic. Are LEDs adjustments different?
  10. sbacpo
    sbacpo Well-Known Member
    Vehicle(s):
    Jul 4, 2019
    122
    116
    Occupation:
    Claybuster
    Garage Profiles:
    Never heard that before.
  11. Hack_Actual
    First Name:
    Justin
    Vehicle(s):
    Jul 18, 2019
    Oklahoma
    231
    180
    There is a built in blocker that lowers the projection of the light on the far left of the D/S headlight. When I aligned mine they were level and that’s how I realigned them after the lift. You can see the dip if you look to the left.
    joeb427 likes this.
  12. DHMag
    DHMag Well-Known Member
    First Name:
    Dale
    Vehicle(s):
    2016 Kia Optima SX, 2019 Ranger XLT Crew cab
    Oct 25, 2018
    San Antonio, TX
    406
    289
    The light isn't projected lower. The cutoff shield in the projector blocks the beam more so to the left for LHD headlamps(to the right in RHD). In reflector lamps, it's built into the reflector (also coordinates with with bulb orientation).
    joeb427 likes this.
  13. Hack_Actual
    First Name:
    Justin
    Vehicle(s):
    Jul 18, 2019
    Oklahoma
    231
    180
    Same same, said a different way. :fistbump:
    joeb427 likes this.
  14. HoosierT
    HoosierT Well-Known Member
    First Name:
    Tyler
    Vehicle(s):
    Feb 1, 2019
    Fishers, IN
    595
    669
    Leveled mine according to the instructions. Super easy but did take way more turns than I expected.
  15. Msfitoy
    Msfitoy Well-Known Member
    First Name:
    Vehicle(s):
    2003 MINI Cooper S Modified, 2009 Chevy Cobalt SS Turbo Modified
    1,860
    2,747
    Occupation:
    Mack Trucks Senior Industrial Designer
    Garage Profiles:
    Where is this bolt? I looked and felt around but am not able to locate it.
Share This Page
