Front USB Ports Stopped Working
Jax
I've had my Ranger for a couple months now with no issues whatsoever. When I usually drive I plug my phone into the front usb ports under the infotainment system to use android auto. However, today upon starting my truck the front ports refuse to charge my phone and do not connect with android auto.
I've tested the back ports and they work to charge my phone but do not connect to sync 3 or android auto. Has anyone else had a similar problem? If so, how did you go about resolving it?
Scottopia
Scott
Mooresville, NC area
'19 Ranger Lariat FX4, '11 GMC Acadia, '03 HD VRod
Grand Sovereign Monarch of Scottopia
Just had this happen tonight on the front left USB Port, also unable to get it working. Worked fine this morning. Right side is ok for now.
jlmotox
CA
Mine has done this a few times but always comes back on... no rhyme or reason that I can tell.
MillerLite87
Miller
2019 Ford Ranger Lariat
I bought a used Lariat about a month ago and same thing left doesn’t work but right one does.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I've had both ports act a little wonky here and there, drop the charging speed or refuse to recognize the device that was plugged in, but it always seems to come back.
I suspect this may also have something to do with the cables being used as well, these ports seem pickier about them than lots of other things are.
UofMEngineer
I had a faulty MCM (USB Hub) in my Fusion that'd act similar. Would connect sometimes, not others, etc.
MillerLite87
Miller
I read this one comment on YouTube that said they remove the battery cable and let it reset and was working normal again.
I’m buying a new Apple cable tomorrow after work since I have a third party to see if that fixes it and if not than I’ll try the battery thing and if that doesn’t do the job, than most likely I’ll be making an appointment with dealership.
LoneRanger19
Brian
United States
2019 Ranger XLT FX4 Magnetic
Same happened to me, both stopped working, tried different cables etc. Then all of a sudden they started to work again and have been ok since then, for now.
UofMEngineer
I'd run it in for a new MCM for these cases. I heard something about some MY19 MCMs having problems, but no details.
Mitch89
Mitchell
Melbourne
Ford Everest MY19.75
Photographer
I had some issues with one of the two USB ports in my Everest, I found rebooting the SYNC3 system got it working again.
Simple car restarts or even leaving it overnight didn’t seem to make a difference.
Hold the Power + Next Track button for a few seconds till the system reboots and see if it has an effect.
Tcarter
Tim
2020 Ford Ranger Supercab
This just happened to my right front usb port yesterday in my 2020 XLT FX2. The left side was still working. I tried cutting off the ignition and removing the key and waiting for sync to shut down. It still didn't work after a restart. After sitting overnight, I just tried it again and it's now working again working again. My guess is after they finally power off after stopping the truck resets the MSM. I don't recall how long they remain powered after the truck is turned off but there is another thread about this. I think it was 60 minutes. Don't ya just love our rolling compters. The other day my speedometer needle began vibrating. Hasn't happened since. I only have a little under 17k miles on this truck. I'm glad I bought the extended warranty for 10yr/75k online from Flood Ford. I'll probably make 10 years before the 75k. Vehicles today are just too computer driven not to have an extra warranty.
