So?
Mine was at 44psi. And you can check it while inside your truck looking at the dash. Sticker on door says 38psi, but it must be a Ford directed issue to put it in the 40’s. It seems like your mad? Why is that ?
Bingo...Because the dealer should actually do their job and prep the truck right? After paying $40K for a truck it should be done and tells me they just rushed it out the door. BTW my sticker says 30 psi so that means they never checked them at all.
How is two extra pounds of air theft? We have a different idea of theft. If anything you got more than you paid for.It's laziness and theft, and I don't care for either one....
It's not 2 lbs of air, he has a 4x2 so most likely his door sticker says 30 psi not 38. So you're saying because you were in the military you should be responsible for doing the dealers job? Hey that's fine if you accept shit service but no way am I going to and neither should he or anyone for that matter. Dealer had a job to do and didn't do it right, that's the bottom line. Even if it were only 2 lbs they still never checked it. Maybe it's me but I strive for excellence not mediocracy.How is two extra pounds of air theft? We have a different idea of theft. If anything you got more than you paid for.
I did open the hood and make sure all fuses were pushed all the way down. I checked the oil before I drove off the lot. Never rely on others with your investment.
If you served the military you would be familiar with daily PMCS. Preventive maintenance checks and services. Checking air pressure is a daily chore before driving a military vehicle.
Not trying to argue with you. Your unhappy about two ponds of air, ok. Good news is your rig is gonna be ok and good thing you corrected the theft.
This was an issue with my delivery, in additional to the tires well over 40 psi.Check your washer fluid also. It may be almost empty and I have seen a few others state the same.
Bingo...It's not 2 lbs of air, he has a 4x2 so most likely his door sticker says 30 psi not 38. So you're saying because you were in the military you should be responsible for doing the dealers job? Hey that's fine if you accept shit service but no way am I going to and neither should he or anyone for that matter. Dealer had a job to do and didn't do it right, that's the bottom line. Even if it were only 2 lbs they still never checked it. Maybe it's me but I strive for excellence not mediocrity.
