FORScan doo-doo-doo
blackc2004
Vallejo, CA
2019 Ford Ranger; 1978 Ford Bronco; 1971 Ford Torino
Hi All,
I followed the directions on the forscan wiki to disable the doo-doo-doo. But it doesn't seem to work for me and now I seem to have an even more ANNOYING doo-doo-doo!
I changed it to match:
RCMUSTANG
Disables three "doo-doo-doo" start-up chimes from cluster
IPC 720-01-02 xxxx x2xx​
Has someone successfully done this? Did I screw something up?
FYI, I was able to successfully change Disable Double Horn Honk and Bambi mode.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
This chime is when doors closed engine start up. It worked on mine. If you're door is open you'll have door open, seatbelt and other chimes.
Arron
Arron
Seattle, WA
2019 Ranger SuperCab Lariat FX4 Sport Magnetic
Software developer
I haven't tested these but they should disable the seatbelt chime and the door ajar chime.
720-01-01 xxxx xx0x xxxx Driver & passenger seatbelt minder status off
720-01-01 xxxx xx2x xxxx Driver seatbelt minder status off
720-01-01 xxxx xx4x xxxx Passenger seatbelt minder status off
720-01-02 xx0x xxxx Disables Door Ajar warning chime (while truck is in Park)
blackc2004
Vallejo, CA
This is weird, but I get in my car this morning, turn it on and NOTHING. Silence! Amazing. I love it!
Yesterday when I was trying it I turned the car off and on 3-4 times and it was still doo-doo-dooing at me but maybe I just wasn't giving it enough time to full reset the system?
Anyway, I confirm this works!!
jerryj11
jerry
ohio
2020 roush ranger
QC
Hi All,
RCMUSTANG
This doesn't work for me either. My code is normally xxxx-901f, soon as i change the 0 to a 2 it also changes the last 2 digits by itself after i click write. It won't let me just change the 1 digit, the doo-be-doo still plays
The new Forscan has two different choices for each module. You want the one that allows you to just hit the check mark on or off. If you’re doing hex code like shown that as factory. Don’t use that one unless you really know what you’re doing. And ALWAYS back up the module you’re in before making changes!
jerryj11
jerry
ohio
2020 roush ranger
QC
there is no option for the 3 chime welcome doo-doo-doo under the worded IPC module. Just primary chime location, and seat belt chimes
kieefer
keith
2019 2WD SuperCab - 97 BMW M3
THANKS !!
Just what I was looking for. ??
@Big Blue
