Flat Towing XLT 4X4
rshippey
Roger
Huntsville AL
2019 Ranger XLT Sport FX4
Just finished checking out my towing equipment for flat towing. Blue Ox base plates, tow bar and wiring system with diodes and RVi3 in cab auxiliary brake system. Every thing worked great. When taking my Ranger out of Neutral Tow I got a 'Check Brake System' warning on the dash read out displayed over the Neutral Tow info. Went ahead and followed the user manual instructions and got it out of Neutral tow mode. Drove it around a bit without further 'Check Brake System' warning. Has anyone else experienced this? Other web searching came up with something to do with the ABS system. Seeking more info on this.
CHS
chris
Crossville, TN
(Ruby) 2021 Ford Ranger Lariat 4X4
I would hope you solved the warning issue by now. It sounds like a missing or misplaced vacuum line check valve
TimmyB
Timothy
Sarasota FL
2021 Ranger Tremor, 2020 Fleetwood Bounder 35P
Hey, Roger. I just got my baseplate installed yesterday so this morning was my first toad experience with it. I got the exact same message. Just like you, I took it out of tow mode and started it up; the message went away and has not reappeared the rest of today.
I am using a Blue Ox Patriot II braking system; other than that, same setup as yours.
CHS
chris
Crossville, TN
I think it may have something to do with the inline vacuum check valves. Since it goes away, it maybe just a kind of resetting itself from the Demco unit.
The reason I stated previously that it may be a missing or miss-placed vacuum line check valve because when I removed the unit from my Jeep Wrangler, I just cut the vacuum line at the tee going to the Demco unit and just plugged the line up at the tee. Once I began driving, I got 2 errors. One was that the Auto start/stop was malfunctioning and the second was a sway control light error was lit up. Once I removed the inline vacuum check valve all was good.
TimmyB
Timothy
Sarasota FL
That's for an air-brake system, I am guessing? I don't have that with the Patriot II. Simply a mechanical floor-mounted pedal that actually depresses the brake pedal using an electronic signal. Sadly, I won't get a chance to tow again for several weeks to investigate.
CHS
chris
Crossville, TN
The system I have is the Demco Duo for standard car, truck hydraulic braking systems. Your thinking I guess the Air Force One system that utilizes the air brakes of Class A motorhomes.
TimmyB
Timothy
Sarasota FL
OK. You were talking about the vacuum line, though, and I don't have one of those and still got the same message as the OP. That's where my confusion comes from.
BillinPCB
Bill
Panama City Beach, FL
1999 Miata, 2019 Ford Ranger Crew Cab XLT, 2019 Ford F53 Motorhome
I get that Check Brake message every time I disconnect. Have been towing my 2019 XLT for about a year and a half (about 5,000 miles) using the Ready Brute tow bar with the mechanical surge brake.
Just Towed from Green Valley to Flagstaff..roughly 300 miles and have logged about 3000 miles on my 2019 Ranger behind the motorhome...Have not had a brake warning message. Puzzling why you are getting this message. Could it be wiring related?
gremlin
Pacific NorthWest
F150, looking to buy a ranger, some other toys
I'd love any more info and photos of the Stay-n-play duo install, I have one in my element toad and love it was planning on putting one into the Ranger as well
