sootie007
- Thread starter
- #1
So I did my very first oil change on my 21 truck hitting 4k this week . I was a little apprehensive because of guys saying the first oil filter from the factory can be stuck to the block. So I bought this specific filter wrench and believe it was worth it . Some said the factory filter was strangely slightly smaller in diameter than the Motorcraft FL910s replacement - I did not see this either . Motivx Tools 74mm 14 Flute Oil Filter Wrench Compatible with Mercedes Benz, Sprinter, VW, Porsche, Volkswagen, Mazda, and More – Also Fits Select Mobil1, Bosch, Mahle and Other Filters The filter spun off pretty easy thank god.
The little plastic screws that hold the rubber dust shield on are kind of hokey. Removing the skid plate was easy as well. I believe it was a single 15 mm to get the oil plug and 2 fasteners off. Then just loosen the front two skid plate fasteners - no need to remove. I went with the Motorcraft FL910S and the Motorcraft 5w-30 syn blend oil purchased off Amazon .
I was surprised my oil life monitor was only at 63% at 4k miles when I reset it . My oil was "used" - really dark brown in color coming out of the pan here in Florida (heat) -but when I poured out the filter onto some white cardboard it was in fact still brown - used but definitely not black. Just based on color I would say so far the Ford is easier on the oil than my Toyotas with similar mileage . I hit it with a light and saw no shimmering whatsoever.
Its kind of a pain but I will continue to do all my own oil changes on this one as I have on all my other trucks over the yrs simply for piece of mind.
