Feniex Industries AI Cube
OFC Ranger
Jack
ZR2
https://www.feniex.com/misc/ai-cube
These are not a new release, but I think this technology is where the future of off-road lighting will ultimately end up.
In a nut shell, it can be dimmed or maxed out at 2100 lumens and can also adjust light spread from 10 degrees to 60 degrees. All of this done from your choice of control method from the cabin.
At some point the lighting industry is going to hit a ceiling and the only innovation left will be two things to build upon;
- components that pull less power for same amount of light
- products become all in one with user controlled preferences on the fly
The tech will probably be above my comfortable price range forever more, as the current tech is going o run you a little over $200 for one light. I imagine as they lights grow in size and power that is going to raise the price tag.
At least until the Chinese over time slowly learn to do it and do it so it lasts.
I imagine given enough time you will see 7" versions of this type of thing with hyper focused 10 degree beams adjustable to over 100 degrees all while pushing 25-35 watts each.
You realize that it's just a short step from an AI light cube to.....
Jason B
2021 XL STX SE 4x2
machinist
OFC Ranger
OFC Ranger
Jack
ZR2
In a way I can understand why it's going that way. It makes it easier to select a light that can switch as needed vs a light that is on or off.
Also for a much higher price these were released by ARB within the last few months
https://arbusa.com/driving-lights/arb-intensity-lights/intensity-iq/
Yea that type of design is what I would toss in the "stop-gap" category. While it gives you multiple choices, it still requires as big foot print as each individual mode is represented by a physical set of lights. I imagine the component count is much higher. The future will be one single physical light source, but mechanics like the AI cube to manipulate that single light source.
OFC Ranger
OFC Ranger
Jack
ZR2
Have you seen Audi's active matrix headlights?
Audi HD Matrix
Are those going to be available in the states? From my understanding we are still operating under some archaic "four lights maximum" laws.
Or at least the states as individuals are.
Something in laws is also why we don't see more factory sequential tail lights directly from factory.
What're you going to do with all the lights you have now?
I couldn't afford to outfit my rig at those prices, plus they are not powerful to replace long distance lighting.
I wonder how the moving parts would hold up with extensive off road use...cool tech tho...
Jason B
2021 XL STX SE 4x2
machinist
Hum, I didn't know those weren't available here.
How does Ford get away with sequential taillights on the Mustang?
OFC Ranger
OFC Ranger
Jack
ZR2
Is that a factory option or after market? I see them sold all over Amazon for the mustang tail lights. Its a small controller box that delays signal in sequence to each housing.
Jason B
2021 XL STX SE 4x2
machinist
Those are standard from the factory. Ford site show 'LED Sequential Taillights' under exterior features for 2023 Mustang.
Appearance
Standard
  • Dual Bright Exhaust with Rolled Tips
  • Shark Fin Antenna
  • Configurable Daytime Running Lights
  • LED Headlamps with LED Signature Lighting Open image overlay for LED Headlamps with LED Signature Lighting
  • LED Front Park Turn Lamps
  • Mirrors, Sideview - Body-Color, Manual Folding, Power Glass
  • Blind Spot Information System (BLIS®) with Cross-Traffic Alert
  • Dual Bright exhaust with rolled polished tips
  • Easy Fuel® capless fuel filler
  • Hood Vents
  • LED Sequential Taillights
Optional
  • Over-the-Top Racing Stripe Ebony
  • Over-the-Top Racing Stripe White
  • Blade decklid spoiler
  • Decklid spoiler delete
I heard Won Hung Lo Inc is busy working on an Amazon edition...
LaBalbe
Ontario / part-time NC
2020 Ranger Lariat
Audi HD Matrix
As innovative as that is, my first thought is "Good Lord, how much is that going to cost to repair?" I mean, you can probably forget about replacing a bulb yourself anymore; and yes, I get that LEDs last a lot longer than traditional bulbs, but eventually they will need replacing. It's just a matter of which you replace first; the lights, or the entire car. Not to mention which, the more components there are, the more that can fail.
