importfighter01
- Joined
- Sep 5, 2020
- Threads
- 19
- Messages
- 384
- Reaction score
- 711
- Location
- Metro Atlanta
- Vehicle(s)
- 2020 Ford Ranger XL SuperCab
- Thread starter
- #1
Hi 5gers! About 2 mos ago I decided to setup a second air feed for the factory airbox. I have my reasons for doing so, but I have no dyno numbers (data) regarding this mod so no reason to extrapolate as I know I will be challenged on “Your reasons and research suck, etc”. Thus this thread is simply to show the final product and what’s possible vs debate the mod.
All that being said I will provide my qualitative review that I noticed an immediate difference in throttle response and accompanying spool as well as top end pull at WOT. Again not making claims, just sharing my observations. Onto pics and descriptions...
I used this velocity stack on the inside of the fender:
https://www.summitracing.com/parts/...qz6i0bxkV6_tSr76S1XLz_Y6fJaCgHIxoCzdcQAvD_BwE
Installing it was accomplished by partially detaching the fender liner after drilling a 3in hole in the sheet metal separating the engine bay from the fender airspace using this:
https://www.homedepot.com/p/Milwauk...5MhSKJwG1mKhgpmsOSxoC_nIQAvD_BwE&gclsrc=aw.ds
With the airbox removed I held the velocity stack tight against the inner fender wall and from the engine bay side I slipped this silicone coupler onto the straight section of the velocity stack:
https://www.amazon.com/Straight-Sil...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
With the velocity stack held in place flush with the fender wall via friction fit with the coupler slipped on, I secured the coupler onto the velocity stack with a 3in hose clamp. I then installed the bottom of the air box, slipping the other end of the coupler into a properly aligned 3in hole in the air box bottom. I then trimmed the coupler back to be more flush with the inner wall of the air box bottom.
In order to ensure the fender feed does not ingest warm air from the engine bay, I sealed off all air gaps where the fender bolts to the body and covered many small holes with white duct tape (cause my truck is white).
As far as where this fender feed draws air from, it comes from 2 places. The first is where the front of the fender liner opens up into the front bumper area (cold air area) and the second is from the fender vent by the door (I have the Ford Performance mesh fender vents, so another cold air area).
All in all not a hard or expensive mod to double the amount of air feeding the factory air box, just measure and remeasure to make sure your holes will line up correctly. As seen in photos you can’t even see the fender feed unless looking for it.
Thanks for reading 5g friends!
