bulldogger
- Thread starter
- #1
Here you go, did it with my wife, absolutely ridiculous how this has too be done. My truck is a lariat crew cab. To start the install, you have to locate the Yellow and Blue wires in the front under the dash. Ford tucks this wire folded up and taped together with blue tape. Ford was kind enough to leave you about 2 inches of wire. This amount of wire makes it extremely difficult to connect the wires using the provided connectors using the hot air gun. Inside the connector is a round tube of solder that has to melt to secure the contact of the wires. I had to use a lighter to get that to melt. I had to protect the rest of the wiring with foil throughout this part of the process. Now with the bottom of the dash apart and the moldings on the rockers removed, you have to run the wires that will tie into the third brake light in the roof at the back of the cab. I had to use a coat hanger to run the wires under the molding of the pillar post between the front and back seats. Now we get to the most frustrating part. The connector that the wires plug into is attached to the back wall of the cab right by the third brake light. The only way to get to it was by dropping the headliner down. Hence from this point started the removal of all of the upper moldings, sun visors, overhead console, interior light, rearview mirror shield, seatbelts that attach to the pillar posts. Once the headliner is down, you now have access to the clip for the new wires. After connecting the wires, we had the fun of putting the truck back together. I don't know where people are getting the idea this is a 30 minute job unless they are getting confused with the 30 minute application in the directions. The 30 minutes in the direction is after you wipe the Redarc modules down with alcohol and apply the foam tape they tell you to wait 30 minutes before sticking them to behind the dash panel. If anyone wants to under take this task I am more then willing to answer questions but they should be pretty soon as I am 59 and will probably forget I own the truck in a few days
