Mickey Thompson Baja Boss A/T has an LT255/85R17/E. It's 34.6" tall and equivalent to a 35-10.00R17.255/90/17 all terrain
or
285/80/17 all terrain
I would advise going on google and looking255/90/17 all terrain
or
No, they do not.
Yea I saw those and it looks like they have a monopoly on that corner of the market, I just wanted to make sure I wasn't missing something.Mickey Thompson Baja Boss A/T has an LT255/85R17/E. It's 34.6" tall and equivalent to a 35-10.00R17.
https://www.mickeythompsontires.com/light-truck-tires/baja-boss-a-t#sizes
My only guess is demand.But y tho?
Yea basically I was looking for 35" tires, but not as wide as my 285 . I really have always liked Toyo tires, but it seems those Mickey's are the only thing out there. That price tag tho...My only guess is demand.
Even at 255/80 r 17 your choices are limited to only E-rated and relatively few manufacturers.
Unfortunately the trend now is overly wide bro truck tires. So while that MT is a new tire, I wouldn't expect more choices to appear on the market.
It takes a guy who feels perfectly adequate to rock the pizza cutters, and most dudes use their truck to make up for other areas where they are "lacking."
I went with the Toyo AT3s for the Ranger. First I've ever used them but I've been VERY impressed.Yea basically I was looking for 35" tires, but not as wide as my 285 . I really have always liked Toyo tires, but it seems those Mickey's are the only thing out there.
Well I'm 3" in the front with no bars and 1" blocks in the rear, I think minor trimming for 35's in 255 will work? Hell maybe no trimming at all in 255's?I went with the Toyo AT3s for the Ranger. First I've ever used them but I've been VERY impressed.
MT makes some really good stuff. I saw those 255/85s after I had gotten my Toyos. If I had the room for 35"s I would've gotten into those MTs for sure.
Personally, I think those MTs on your RTRs would perform, and look, amazing on your truck. If you have the room for 35"s you should jump on them.
Pizza cutters are dumb if we are being honest sure they can increase your clearance in a vacuum but in reality the increased ground pressure and lack of contact patch will screw you over more than the benefits you would get from being slightly higher. If you are going offroad big and wide are your best friends just look at the sherp that things tires are so fat it cant even turn without tank steering yet it will quite literally get through anything I have yet to see anyone get one stuckMy only guess is demand.
so the most important thing is gonna be your offset are you on stock wheels? I am on a 3.5 inch lift and run lt315 70 r17's beautifully both on and off road as you can see idk what the offset is off the bat but just look up bronco sasquatch offset if you are curiousYea basically I was looking for 35" tires, but not as wide as my 285 . I really have always liked Toyo tires, but it seems those Mickey's are the only thing out there. That price tag tho...
The big issue is gonna be the diameter not the width regardless of what width you go if you want 35's you will need to cut or push in the crash bars when I went 35's that was the biggest issue even before trying to turn the actual diameterWell I'm 3" in the front with no bars and 1" blocks in the rear, I think minor trimming for 35's in 255 will work? Hell maybe no trimming at all in 255's?
Would be awesome to get another 2+ in height off just rubber.
As already discussed I am on RTR wheels (0+ offset) on 3" front and 1" rear and I currently have no bars.The big issue is gonna be the diameter not the width regardless of what width you go if you want 35's you will need to cut or push in the crash bars when I went 35's that was the biggest issue even before trying to turn the actual diameter
