Advertisement
DIY oil service
Do you service your truck yourself?
  • I do my own services.
  • I take it to the dealership or service station.
Results are only viewable after voting.
MrRisk
Nick
Ranger XLT
Mechanic
Its that time, 10,000 Mile service.
First things first I put this big boy up on the lift and inspected everything for damage/wear and tear. I didnt find anything alarming so I got started with the service.
Pulled the plug and watched the nasty black oil drain out, I was not surprised to see it get on the crossmember.
After draining the oil I found that Ford decided to locate the filter in what seemed to be the dumbest area possible.
Upon further inspection I found that in the wheel arch there is a rubber mud guard that can be easily removed to make room for my oil filter wrench, needless to say it was much less terrible than I initially thought.
Once again it seemed that a mess was going to be made, thankfully they thought ahead once again. Under the filter is a channel that helps the oil flow out of the back of the engine compartment which keeps the oil from going everywhere. After I replaced the filter I hosed the area down with some brake parts cleaner to rinse the residual oil out and we were back in business.
My parts supplier recommended an FL-910S instead of the FL-400S, from what Ive read either work fine.
And here is the obligatory post oil service photo.
Cheers and I hope this will be helpful to at least one person in the future.
Advertisement
MrRisk
MrRisk
Nick
Ranger XLT
Mechanic
  • Thread starter
  • Thread Starter
  • #3
Thanks for the thread.
What's the differences between FL-910S vs FL-400S,
The FL-400S is slightly taller, only real difference.
SFB
Daniel
Fullerton California
Thanks, very helpful. I have always been one who liked pre filling the filter, not any more! Not user friendly when it's full of oil. Will be changing my "break in oil" this coming weekend.
Rob R
Phila
2019 ford Ranger XLT
Septa Railroad
I just had to research that myself when I owned my 69 camaro I always used the truck 350 filter over the car because I liked the bigger filter and more one capacity.. So I looked up the difference between the two on motor craft web site the 910 had a higher pressure rating which is better so the filter doesn’t bypass as much oil as the 400.. learned something new today for the first time never thought there was a pressure difference..
PNW_Ranger87
Erik
Renton, WA
2019 Ranger XLT 4X4
Parts Specialist
Yep! Lower volume, higher pressure! :like:
Nice photos! Doing my first change tomorrow at ~2K miles. :sunglasses:
Rob R
Phila
Septa Railroad
Have not changed mine yet have 3123 on it thought about it. I never waited this long to change any oil but I think it’s running synthetic and was going to push it till 5 k or maybe just do it at 3500
PNW_Ranger87
Erik
Renton, WA
2019 Ranger XLT 4X4
Parts Specialist
I believe the factory uses the Motorcraft Synthetic Blend. I know that we use Motorcraft SynBlend in our standard oil changes. I'm switching to Motorcraft Full Synthetic and plan on changing the oil every 6K miles.
HenryMac
Central Colorado
2019 Ranger SuperCab XL - STX - FX4 - Magnetic
.... the difference between the two on motor craft web site the 910 had a higher pressure rating which is better so the filter doesn’t bypass as much oil as the 400....
How much higher pressure? That will mean a higher likelihood of oil leakage at seals.
Rob R
Phila
Septa Railroad
910. Was 20 psi and the 400 was 14.5 psi
Rob R
Phila
Septa Railroad
Once everything is drained, I like to crank the engine over to get every drop out.:thumbsup:
Cool I like that Parts Truck let me know when the parts are available LOL
Toytec
Central NC
Nice thread. Thanks. I'm a petroleum transfer specialist myself (oil changer) and wondering that once I get it up on the lift will the oil filter be more accessible, Guess not I see.
I have a quick lane within walking distance from where I work and was planning on using up the points on the first 3 services just to get the records in the system.
Just a thought, has anyone requested full synthetic other than blend at one of these places? Were the points the same regardless?
Advertisement
Advertisement
