Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
Available for 5 ft and 6ft beds.
Message me for forum pricing.
Frank
2019-2021 Ford Ranger DECKED Truck Bed Organizer 5ft Bed MF3
2019-2021 Ford Ranger DECKED Truck Bed Organizer 6ft Bed MF4
Highlights:
Organization and storage just got a whole lot easier to manage in the bed of your 2019-2021 Ford Ranger with this Sliding Drawer System from DECKED. Designed to be a perfect fit for your bed size, each of the two sliding drawers pull out to provide countless storage and organization options. Each of the two drawers lock to provide a new level of safety and security and give you peace of mind when your truck is unattended. Manufactured in the U.S.A., with a 2000 pound deck load rating, each system is custom cut to fit the exact specifications of the bed of your full size pick-up truck without any drilling needed. It's built from 100% recycled high-density polyethylene which is co-molded to a steel sub frame and installs utilizing your truck bed's existing tie-downs. No drilling is required and your new tie-downs simply install on rails on the new deck of your truck bed. DECKED Locking Drawers Capable Of Holding Up To 200lbs. Each
Weatherproof and secure, both of the sliding drawers can be locked with a key to protect your valuable gear and keep guns safely protected from theft or the curiosity of children. The storage options are endless as each drawer rolls out smoothly on sealed bearing wheels and can hold up to 200 pounds, making them handy for anything from hauling heavy loads to and from the job site to providing a temporary storage solution for hauling back your catch from your fishing trip as well. The Sliding Storage System also makes for a perfect mobile work station since each drawer slides out to the desired location of your powerful and heavy tools in an easy to reach and use location so that you don't have to keep searching for tools out of your Ranger's bed. The flexibility of this universal truck bed solution makes it perfect for work, play or both. Each DECKED system also comes with a Desert Tan D-Box, a Desert Tan Cross-Box, a pair of drawer dividers, and a drawer organizer. All other accessories are available at additional cost.
Additional Features:
Important Fitment Notes:
Some Accessories Sold Separately: this bed drawer system comes standard with a Desert Tan D-Box, a Desert Tan Cross-Box, a pair of drawer dividers, and a drawer organizer. Core-Trax rails, locks, and drain plugs are available at additional cost from our drop-down menu above.
Frank
Highlights:
- Heavy-duty, drop-in bed drawer system
- Features two large-capacity drawers
- Extremely strong construction
- Can handle up to 2,000lbs of load
- No-Drill Installation
- Comes with all necessary hardware
- Storage organization accessories also included
- Backed by a 3-year limited warranty
- Easy operation with oversized cast aluminum handles.
- Features full-size drawer and one narrow drawer.
- Compatible with top rail mounted ladder racks & some tonneaus.
- DECKED can handle UV light, moisture, and extreme heat or cold.
- Installation hardware and detailed instructions are included and installs or can be removed in about 20 minutes.
- Measures 4'8" long and weighs 205 pounds.
- Does NOT fit with a drop-in plastic bed liner or BedRug Kits, but WILL work with a spray-in bed liner.
