Climate control.
Ranger3
Dj
New jersey
2020 Ranger Xlt Sport 4x4
Store Mgr
Here's a quick question since it's winter time and I start my car I usually keep it on auto but when I'm driving I have the climate control on the screen I hit the forward vent and then I hit the floor button they both light up and put fan speed on high but hardly any air comes out of the forward vents when fan speed is on hi. Can anyone confirm if this is normal?
Advertisement
Ranger3
Ranger3
Dj
New jersey
Store Mgr
a33maxi
New England
2021 Ford Ranger XLT 4x4
I do the same and get quite a bit of airflow out of the forward vents, even with the fan speed set to 2-3. What happens if you select forward only?
Ranger3
Ranger3
Dj
New jersey
Store Mgr
It super high when it's just forward it's perfect...do u think I need to take her in?
gasmanjohn
Itasca, IL
2019 Ranger XLT FX4, 2019 Beetle Final Edition (wife's)
Gas leak inspector
Mine has always acted like this. The faster the fan speed, the less that comes out of the forward vents. "Auto" works best for me but it uses the AC compressor and my mileage drops.
Ranger3
Ranger3
Dj
New jersey
Store Mgr
So yours does the same thing..say on 80 degrees with forward n floor on? I also noticed the more I increase the fan speed the less air comes out in the forward vents is this true with yours?
gasmanjohn
Itasca, IL
Gas leak inspector
That's exactly it.
stringbreaker
washington state
2019 Ranger XLT
Mine has the worst heater A/C unit in any vehicle I have ever owned. Seems to take a long time to heat up except the defrost works well floor vents are crap I rarely use them
gasmanjohn
Itasca, IL
Gas leak inspector
So I assume this is normal?
I think it's just a poorly designed blend system. Although, my wife's VW Bug with auto-climate acts the same way. Personally, I'd prefer a manual system but you can't have that with the 8" screen.
GA
I just tested mine and the airflow from the center two vents is much lower than the side vents when the floor vents are also active.
Putting it on just the dash vents and all 4 are pretty similar flow.
Ranger3
Ranger3
Dj
New jersey
Store Mgr
Thank you Dr zayas I guess it's normal operation I'm not going to take her in then
Advertisement
Advertisement
