Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
These are being discontinued and will no longer be available, Normally $299.99 on Sale for $219.99, get them while they last!
Rigid Industries D-Series DOT/SAE Flood Lights- White - Pair 504813
Highlights:
We all love what Rigid Industries has done to take automotive LED lighting to the next level for off-road lighting. Now they've taken their innovative LED lighting technology even further by introducing a new series of DOT/SAE-approved lights for every day use as well. The new D-Series Flood Lights are completely street legal and allow for a very wide and smooth beam pattern with minimal height. Their new Front Fog Lights come in a set of (2) and are set in their indestructible Dually housing. You can't go wrong by replacing the factory stock flood lights on your Ford F-150, Super Duty or other off-road vehicle your choice.
High-Powered Flood Light Beam Pattern
Utilizing their innovative LED optics system, Rigid is able to provide a much more powerful beam of light than factory stock to illuminate a wide area with clear and crisp light. Using their new SAE optical system, Rigid is able to give your truck an SAE J583-compliant beam, powered by 4 LEDs, to create the ultimate fog light. Now you can replace those worthless factory fogs using Rigid's OE fog light kit and have LED lights that you can leave on for regular use. While being incredibly powerful, this pair of lights will not draw much power so you won't have to worry about them overly taxing your truck's battery.
30 Flood Light Beam Pattern with Impressive Range
Each flood light unit in this pair features 4 powerful LEDs arranged in a 2x2 pattern. Rigid's patented Hybrid Optics System utilizes a combination of lens and reflector to maximize the amount of light emitted from the LED, allowing you to project it exactly where you want it. It casts a beam in a 30 pattern to produce a wide amount of lighting coverage so you won't have problems illuminating your way, on or off-road, long after the sun goes down.
Extraordinarily Strong and Durable LED Fog Lights
Installing a pair of Rigid D-Series DOT/SAE-Approved Flood Lights is easily one of the strongest and most durable upgrades you can do for your truck. Each light is built to withstand the most brutal conditions on the planet. Each light has high-quality LED boards that are resistant to impact and vibration to keep them functioning as you thunder down the roads. The boards are further protected by an extra-strong cast aluminum housing and a thick polycarbonate lens that can withstand amazing levels of punishment. The housings feature oversized, built-in heat sinks that allow you to run your floods without risking overheating and damage.
SAE/DOT Approval: these lights are SAE and DOT-Approved for street use, if and only if the lights are mounted below your vehicle's grille for use as a fog light or auxiliary driving light. Any other use may not be street-legal.
Features:
Highlights:
- Vastly Increased Light Output
- Patented Hybrid Optics
- Instand On/Off - No Warm-Up
- Integrated Thermal Management
- Pressure Vented to Avoid Condensation
Features:
- 30 Flood Pattern
- Compliant with SAE J583
- Instant On / Off - No Warm Up
- Over / Under Voltage Protection
- Cast Aluminum Housing
- Durable Polycarbonate Lens
- GORE Pressure Equalizing Vent
- Designed, Engineered, & Assembled in the USA
- Watts: 22
- Amp Draw: 1.53
- LEDs: 4
- Raw Lumens: 1760
- Lux @ 10m: 106
- Beam Distance: 103m
- Peak Beam Intensity: 10570
