- Joined
- Aug 24, 2022
- Threads
- 20
- Messages
- 1,673
- Reaction score
- 3,553
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
- Thread starter
- #1
i am working on a full complete tutorial on how the charging system works, but I need some help. This system is somewhat confusing in regard to the system description given in the Service Manuals. I think I have it down, but I still have some questions.
I would like to create a -one stop posting that covers the whole system, including the trigger voltages that generate most of the issues owners have. I have pieced together a good amount of info, through various sources.
The issue is the system operation is never explained in detail:
I am a former auto tech but have been out of the field professionally for 30 years, so when I dove into this system out of curiosity on how it works, I was met with a ton of explanations from forums and the Service Manuals are very vague. so that leaves me confused on what is FACT and what is FICTION
From the Service Manual:
(Note: Even though this is for a 2020 Ranger, the 80% Ref: here is 75% for our Ranger, I deduced that by 75% is not mentioned anywhere except on this forum and viewed in FORscan. Battery Target SOC 75%, so this is a ref from another platform that did not get changed for the Ranger
Charging System
The PCM controlled Smart Charge charging system determines the optimal voltage setpoint for the charging system and communicates this information to the voltage regulator. The Smart Charge charging system is designed to set a DTC when a charging system fault is present. All of the Diagnostic Trouble Codes (DTCs) can set continuous faults, but not all Diagnostic Trouble Codes (DTCs) set as on-demand faults.
The smart regenerative charge system primary strategy is stored in the BCM . The BCM receives information relating to the battery condition from the battery monitoring sensor via a LIN . The BCM calculates and sends the set value needed for the generator charging voltage via the HS-CAN to the PCM . The PCM then adjusts the value received (if necessary) and sends it to the generator via a different LIN . The charging voltage is adjusted depending on various parameters, such as the current level of engine efficiency. The smallest possible set value for the generator voltage is 12.2 volts, while the maximum charging voltage can be anywhere between 14.5 and 14.9 volts. However, when the battery is in a refresh phase, the voltage may occasionally reach up to 15.2 volts. These refresh phases are required when the battery charge status is 80% over long periods of time, which increases the risk of sulfation in the battery cells.
My Question Is: What does this line mean (From Above)
Now, my current understanding of this system is this, but I have varying descriptions and I don't know which one is correct
1. The system will maintain 75% SOC at all times by either increasing or decreasing charging voltage, charge at full charging rate up to 75% and then back off voltage as long as the battery can maintain 75% SOC
2. The charging system is capable of charging past 75% to 100%, at a lower charging voltage, once it reaches 100%, charging voltage is shut off until SOC drops back down to 75% and then the cycle repeats and anything below 75% is full charging voltage
3. The charging system charges to 75% and maintains 75% and then using Smart Reg Charging, during de-acceleration, the generator produces an extra boost charge into the battery thus raising the SOC to 100% which I don't think the Ranger has this feature, like other Ford models and this is the reason for only charging to 75%, leaving 25% buffer for the boost.
4. The system minimum is to always maintain is 75% and is capable of charging past 75% to 100%, if it sits in this range (75-100) for an extended period of time voltage is reduced and this allows the Battey SOC to drop back to 75%
I am thinking either #2 or #4 is correct
So, please help me understand this system, there are hundreds of explanations are over the web, but no definitive answers on how it actually works, only guess work, and I hate guessing on how things work. I am looking for an exact operation of the system
What I am currently doing:
I have a voltmeter, plugged into the PowerPoint, its verified accurate, I monitored the charging levels at 75%, bumped up to 80%, and now am currently on 90% SOC. via FORscan, my 80% test is complete and will revisit 75% as I did not document what the switching voltages were, I just noted what the max voltage was during my drives. So, I was just looking for some answers on this system as to what I should see when I set it back to the factory 75% SOC
I did note that driving at night vs day, makes a difference - Daytime you see more accurate voltage readings (no heavy amp draws)
I am looking for help from anybody that has actually worked with this system
Thanks for your help
Charging System
