Carrier bearing bolt torque
Tbalt14
Tom
Franklin Grove, IL
2022 Ford Ranger
Electronic tech
I searched but didn't find. Does anyone know the carrier bearing torque specs? 2022 Ranger 4x4
Thanks
JimJ
Twisp Washington
07 FX4. Level2. 2022 SC FX4 on order
Thanks
Take size and grade of bolt thread size etc and look up the torque value for that size bolt.
RangerBill
PA
Thanks
The shop manual for a 2019 says:
Install a new driveshaft yoke washer and nut.
Torque : 111 lb.ft (150 Nm)
The bolts to mount the bearing to the frame are:
The driveshaft center bearing bolts
Torque : 35 lb.ft (48 Nm)
I am not sure which torque specs you need, so I gave you both.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
You should torque bolts to not 2.
Not too tight, not too loose.o_O
Tbalt14
Tom
Franklin Grove, IL
2022 Ford Ranger
Electronic tech
Thank you!
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
Thanks I was just looking for this as im replacing the carrier bearing.
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
Where did you find a carrier bearing?
Lakeland ford in Fl, ordered it Friday it came in today it was set to come on Friday this week. Super guys to deal with if you order online call them with the order number and they will try to get it to you sooner. Which in my case was 5 day sooner
Stevedbvik1
2022 Ranger Tremor XLT
Thanks. If you get a chance can you post the part # that they sold you.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
I routinely torque to 'that's not going to fall out' lb/ft.
In the case of the carrier-bearing bolts, they got a dab of blue Loctite as well.
