LoneRNGR
- First Name
- John
- Joined
- May 8, 2020
- Threads
- 11
- Messages
- 472
- Reaction score
- 856
- Location
- Lubbock, Texas
- Vehicle(s)
- 2020 Ford Ranger XLT
- Occupation
- Systems Engineer
- Thread starter
- #1
So I think I can do this at a pretty affordable price. Here is where I'm starting.
☒ = Already part of the FX4 package or I already have it.
Tremor Package – Enhanced Performance Features
☐ Off-road tuned suspension
☐ FOX 2.0 monotube dampers with rear piggyback reservoirs
☐ Rear multi-leaf springs
☐ 9.7” of ground clearance
☐ 32” General Grabber A/TX all-terrain off-road tires
☐ 6-switch auxiliary power pack
☐ Black exposed steel bash plate
☒ Terrain Management System
☒ Trail Control
☒ 4x4 electronic rear locking differential
☒ Off-road screen
Tremor Package – Upgraded Styling
☐ Hoop steps
☐ 17” Magnetic-painted aluminum wheels
☐ TREMOR box-side decal
☐ Unique grill with Magnetic-painted surround, black bars and red nostril accents
☐ Magnetic-painted wheel-lip moldings with 1" wider offset
☒ Magnetic-painted bumpers
☐ Ebony seats with Miko suede inserts and TREMOR stitched into the seat backs
☐ Black interior accents
☒ All-Weather floor mats
Off-Road Tuned Suspension ☐
I would like to build my stock Ranger FX4 to similar specifications as the Tremor package, especially the Performance Features, but not necessarily with the same brands of parts. I was going to check-off this section since the FX4 is already advertised as having an "off-road tuned suspension," but we will see where this goes.
FOX 2.0 Monotube Dampers with Rear Piggyback Reservoirs ☐
I plan to replace the FX4 shocks with Bilstein 5100. The front shocks allow pretensioning the spring to provide lift to the front-end. I expect to set the height to 0.6" which I expect will be closest to the Tremor setup. The version of the Bilstein 5100 shocks that do have reservoir cylinders only have a 90 day warranty, whereas the standard rear shocks have a limited lifetime warranty, so I'm inclined to stick with standard.
Rear Multi-Leaf Springs ☐
I do not know why Ford didn't go with a multi-leaf spring in the United States. It probably has to do with cost saving. All of the aftermarket springs I have seen for the Ranger provide lift, which I do not want. So I need help with this one. Continue using the single spring, which will probably be fine as long as I don't exceed its limits, or go with an alternative? And what would be the alternative?
9.7” of Ground Clearance ☐
I think the FX4 has 8.9" of ground clearance. Does anyone know where the lowest point on the Ranger is so that I can verify this?
32” General Grabber A/TX All-Terrain Off-Road Tires ☐
General makes three different Grabber A/TX tires in 265/70R17, so I don't know specifically which one they are using, but it looks like it is probably a tire with an "E" load range and would weigh about 52 lbs. Seems to me that a better fit would be a BFGoodrich All-Terrain T/A KO2 that can be had with a "C" class load range and would be a much lighter 46 lbs.
6-switch auxiliary power pack ☒
I don't want to replace the dash tray. That's where I keep my fries. I've got this one crossed off already. I'll be installing a Light Force switch fascia with 3 switch plates. I'll use one to switch a light, another will have a RJ-45 microphone connector for a ham transceiver, and the third plate will eventually have a Red Arc brake controller knob.
Black exposed steel bash plate ☐
Paint the one I got? Have it powder coated? Put Rhino-Liner on it? Just leave it alone? Ideas?
All of the features below are checked off because they come with the FX4 package:
Terrain Management System ☒
Trail Control ☒
4x4 electronic rear locking differential ☒
Off-road screen ☒
Now, to the styling features.
Hoop steps ☒
I'm going to check this box off. I have Go Rhino running boards already and even though I don't particularly like running boards or steps, smaller members of my family will not go without them.
17” Magnetic-Painted Aluminum Wheels ☒
I have the sport package wheel that I think look great, so I'm not going to switch these. It is not in the Ford Tremor literature, but I'm told that the wheels may have a slightly different offset making the stance just a little bit wider (hence the wider wheel-lip moldings). Does anyone know what this offset is? I have some 1" spacers that I might use on the sport wheels.
So we are looking at a 0.6" level in the front, 265/70R17 tires and 1" wheel spacers. I don't think there will be any clearance issues, but I'm not certain. I really don't want to cut out or replace the intrusion beams.
TREMOR Box-Side Decal ☐
I have a sticker that says FX4 on there now. I also have a Raptor styled "RANGER" sticker. Any other ideas?
Unique Grill with Magnetic-Painted Surround, Black Bars and Red Nostril Accents ☐
I have the XLT grill and I'm not interested in replacing it. I don't like the Lariat grill or the Raptor style F O R D grill. Looking for ideas regarding "colored inserts."
Magnetic-Painted Wheel-Lip Moldings with 1" Wider Offset ☒
I'm going to mark this off for now. Mine are already magnetic painted. Unless the tire sticks way out, then I'll leave it be.
Magnetic-Painted Bumpers ☒
I have that with the sport package.
Ebony Seats with Miko Suede Inserts and TREMOR Stitched Into the Seat Backs ☐
My seats are black (maybe they are Ebony ;-). I think I'm going to leave this alone but I'll listen to any suggestions...
Black Interior Accents ☐
What are these? Everything in my truck is black, except the trim around the AC vents... oh these are black on the Tremor? Maybe I can get Ebony Interior Accents.
All-Weather Floor Mats ☒
Yep. I have these.
I appreciate all comments and I'll document my progress here.
☒ Trail Control
☒ Off-road screen
☐ Hoop steps
Trail Control ☒
Off-road screen ☒
Hoop steps ☒
Yep. I have these.
