Bed rail height?
Discussion in 'General Ford Ranger Discussions' started by Tomsriv, Nov 28, 2018.
  1. Tomsriv
    Tomsriv Member
    First Name:
    Tom
    Vehicle(s):
    2006 Dodge Magnum RT (345 V8), 1971 Buick Riviera (455 V8)
    Nov 28, 2018
    Camarillo, CA
    Modern truck bed sides have gotten so tall that I cannot reach over them. I’m 5’9” and most full size trucks have beds that are as tall as my shoulders. The old ranger was as tall as my elbow and made reaching into the bed very easy. I often carry car parts for restoration projects I’m working on so not haveing to climb into the bed every time I need something is a must.
    I looked in the specs but didn’t see one for bed rail height (or maybe I’m blind). Can anyone tell me the height on 4x2 rangers?
    Anyone else annoyed by this? I think it has to do with aerodynamics. Less distance from bed rail to roof is better for aerodynamics. I’m used to old trucks or the ‘65 Chevy stepside I had where it was real easy to step and reach.
  2. DHare
    DHare Well-Known Member
    First Name:
    Vehicle(s):
    2019 Ford Ranger Lariat - Saber; 2014 GMC Terrain
    Sep 28, 2018
    Missouri
    330
    194
    You can add aftermarket side steps to most trucks so you can step up and then reach into the bed.
  3. Tomsriv
    Tomsriv Member
    First Name:
    Tom
    Vehicle(s):
    Nov 28, 2018
    Camarillo, CA
    Their is not enough room between the rear door and tire to mount a step right there. If I used a step from the door it would require twisting and balancing. Can’t do that while trying to grab a 20 lb starter motor from the bed.
  4. rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    2,841
    1,588
    Garage Profiles:
  5. Tomsriv
    Tomsriv Member
    First Name:
    Tom
    Vehicle(s):
    Nov 28, 2018
    Camarillo, CA
    Thank you for the replies but I’m really just curious to find out how tall the bed sides are. If they are too tall I will lower the truck if possible. It is much more convenient than having to unfold a step or setting heavy objects at the end of the bed where they will slide forward and dent the bed the first time I hit the brakes.
  6. Tomsriv
    Tomsriv Member
    First Name:
    Tom
    Vehicle(s):
    Nov 28, 2018
    Camarillo, CA
    #6 Nov 28, 2018
    I mentioned lowering so I will probably get some hate, but I just want the same easy usability of the old ranger. I’ve looked at the Canyon/Colorado and they are jacked up way too high.
    I restore classic cars and often put various heavy and greasy parts in the back and need to make many stops at junk yards and parts stores to compare a part to either fix or fabricate a replacement. So having to open the tailgate and climb in multiple times a day is not time efficient.
  7. blackdog
    blackdog Active Member
    First Name:
    JM
    Vehicle(s):
    1986 f150 flareside
    Oct 17, 2018
    Long Island
    33
    https://www.realtruck.com/decked-tr...chpNfuGT3G4jS_rqvlLXYnU-R1xKEGXRoCQfQQAvD_BwE
    these might be a solution for you without having to lower the truck. drawers slide out and you can put things on top that will be easier to reach from the sides
  8. EFNFAST
    EFNFAST Member
    First Name:
    Vehicle(s):
    1990 ZR-1 Corvette, 2019 Ranger
    Nov 22, 2018
    New Hampshire
    I agree, bed heights are getting rediculous.
    Tomsriv likes this.
  9. rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    2,841
    1,588
    Garage Profiles:
    Have you looked into a Ford Transit Van? The load height is only 29”, which should be lower than the Ranger’s bed height.
    Edit: 4x2 Ranger bed height is about 34”, so it’s almost 1/2 foot higher.
  10. Tomsriv
    Tomsriv Member
    First Name:
    Tom
    Vehicle(s):
    Nov 28, 2018
    Camarillo, CA
  11. WXman
    WXman Well-Known Member
    First Name:
    Shawn
    Vehicle(s):
    2018 Jeep Wrangler Unlimited
    Oct 17, 2018
    Central Kentucky
    71
    Mark Allen made a big deal of this at the Jeep Gladiator display during the auto show. They specifically made the Gladiator bed rails short enough to allow reaching fully into the bed. He's under 6' tall, and was still able to reach over and put his hand flat on the load floor of the bed. That's with factory 33" tires. Very nice.
    I wish Ford and GM would think like this.
    smlford and Tomsriv like this.
  12. Tomsriv
    Tomsriv Member
    First Name:
    Tom
    Vehicle(s):
    Nov 28, 2018
    Camarillo, CA
    Maybe a Jeep in my future. But those power window switches on the center console instead of the door drive me crazy. I’m hard to please!
  13. WXman
    First Name:
    Shawn
    Vehicle(s):
    Oct 17, 2018
    Central Kentucky
    71
    Haha yep! But that's the price you pay to be able to remove all the doors in minutes!
    Tomsriv likes this.
  14. rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    2,841
    1,588
    Garage Profiles:
    #14 Dec 3, 2018
    Bed is super deep with the high bed walls. I don't have a problem with the ability to carry more stuff, but I imagine it can be hard to reach over.
    From Up close with the 2019 Ford Ranger
    Tomsriv likes this.
  15. mjbrow
    mjbrow Member
    First Name:
    Vehicle(s):
    2013 GTI
    Dec 4, 2018
    Knoxville
    Is there any info on the actual bed height? Bottom of bed to top of rails? Or to top of the cab, if someone is planning on installing a flush truck cap?
Share This Page
