Muffin1
- Thread starter
- #1
So after my truck sat for a couple weeks the battery was pretty much dead the radio presets were still there i got it charged and have been keeping it on the Battery Tender w/1.5 amp trickle and it's been starting fine with 12.6 multimeter measured volts before starting. Curious though as i am i did a peristatic drain test and this is what i found.
It reads as 1.57 amps draw, which from what I’ve read generally it should be from .25 to .50 Interesting when I made the connections with the leads the headlights came on for a second or two then settled down to the 1.57. I thought maybe the auto headlights switch was positioned to on but it wasn't.
There was nothing else connected inside the truck. I also closed the hood during the test i hooked up jumpers that reached outside to the grill and checked it from there, same reading (1.57) as with hood open, wasn't sure if the hood ajar warning would skew the reading.
Have this coming Monday
https://smile.amazon.com/dp/B07DDDDSK9?psc=1&ref=ppx_yo2ov_dt_b_product_details
Hopefully i will get this figured out if the battery is slowly dying like i read another thread here and that may be the issue. My battery is now 40 months old according to the date code.
https://www.ranger5g.com/forum/threads/power-drain.7678/
