HeatXfer
The amount of useful information in these threads and the commitment to follow through and resolution is remarkable. Everytime I explore an issue or try to suss out an answer, I turn to this forum and find a masterclass on suspension, tires, electrical and everything Ranger. I didn't want to start yet another BMS/Charging system thread, so this thread it is:
I replaced the original battery after 3½yrs after getting the "start the engine or else" message. I installed a new AGM ($$$), I did not reset the BMS ('cause I hadn't read it here yet), and a year later all the alert tones changed and I start getting "the message" again.
I check the forum, disco the BMS and break out the 'ol Batery Tender. I've got a volt meter plugged into thr cigarette lighter and everything looked good: off the tender and not driven for several days I had 12.4 - 12.6v, up to 14.4v while driving. I reset the BMS to 90% and have been monitoring: no issues, I haven't had to use the tender. All good.
Then I decided to reset the BMS. I'm now seeing charging voltage as high as 15.4v, but typically at 15.15v. It's been doing this for about a week, with and without the BMS. I have yet to see it drop into normal range. Could this be the 'refresh' cycle because the battery was run down before?
