SilverXLT6
- Thread starter
- #1
I go to start truck and it acts like battery is dead.
I put charger on 6 amp, go to check it 45 minutes later and it's already at 12.4V with charger off , it was 11.5V when I put charger on.
That seems too fast?
I remove charger .
Truck starts right up. I check voltage while truck is at high idle and it's over 14 volts.
Does a 2019 Ranger have BMS ?
Is the battery bad? What happened there?
IF I replace the battery do I need AGM ?
Will either a H6 or H7 fit ?
Is my charging system set to 70% ? Like this post says ? Will a Ford Tech change that for me ? :
" Our factory settings in the BCM have the charge capacity set to 70% of total capacity from factory "
Thanks!
I remove charger .
Thanks!
