Banks iDash
RazzleRanger
2022 Ranger XLT FX4 Shadow Black
That seems strange? Why would they suddenly glue the vent in place?
KB3B-21045651-AAW
Strange but true. Must have been yet another cost save!
Thanks for the part number. Went to dealer but the vent doesn’t seem to be order-able. The entire upper dash pad needs to be replaced to revert the gauge revision on the 2022 (since I had to cut it out) and I assume the 2023 my also. So beware! I will try to look for a used vent from a junk yard or just let the truck go with the gauge when or if I ever sell it. Thanks again.
Muscleford
George
Ohio north coast
Retired CFO
Installed my HN Customs gauge pod mount this afternoon. Fit and finish of this handmade piece is incredible. 10/10 and worth the wait.
Here are some pics of the install. Had to drill a hole in the dash to route the wires to the OBD port. Took my time and it came out great.
Having trouble findng eirht website, d you by chance have a link?
Thanks
George
Dr3wDrop
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Thanks
George
Look at post #16 for the Aeroforce pod. If you want the one I have, you need to reach out to HNCustoms on Instagram for them to make you one. They only make them by request.
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
Mine was the same as @RazzleRanger, glued in place! Had to cut around the seam with a knife to remove it. The Aeropod doesn't even fit well, it's a little loose so I guess I need to glue that in too. There are no clips or anything on the vent (what's left of it).
Dr3wDrop
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Dang. That’s crazy.
Wablackwell22
Andy
Columbia, SC
23 Ranger
Paralegal
Added a new page layout to the idash.
1) Horsepower from the ECU
2) Torque calculated by the ECU
3) Fuel Rail Pressure
4) Accelerator Pedal Percentage (assume this translates to WOT).
The funny thing is my foot was to the floor for a good second so category #4 saying the throttle was only 77% open was enlightening.
I'm curious, does anyone know how the ECU is able to read the HP and TQ numbers. I had this same feature on my Stinger, but was always curious as to how it "knew" the HP/TQ I was putting down. Is it just calculating based on speed/RPM etc?
RAYJAY
UNION DALE PA
how bad was fishing the wire from the bottom up after the drill/ and any thing to watch out for behind the duct ?
Dr3wDrop
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
So I started with a small pilot hole and stuck my hand up under the dash till i felt the bit to make sure nothing was in the way. There is what feels like a hvac plastic box/line in that area you want to avoid. I ended up using step bits so I didn't accidentally drill too far down. I also made sure the hole was big enough for the molex connector to go through. Didn’t want to mess with de-pinning it.
My test wire was a thicker gauge that was more rigid so I could route it in the dash. Once i got my path, I taped the harness to the wire and pulled it through.
Loweredon33s
Baltimore
2021 Ranger
Performance person
The throttle body doesn’t follow the pedal directly. It’s rarely fully open at wot unless the tuning specifically calls for it. It moves the throttle body to control power and limit boost.
RAYJAY
UNION DALE PA
on my 2020 it just came right out out.
RAYJAY
UNION DALE PA
RAYJAY
UNION DALE PA
thank you for the info the install went flawless.. very easy to install once you remove the ac vent panel, still getting it all setup the way i want it to work, may go either with the chrome ring or the black ring the carbon fiber looks ok but ....
Tremor416
Phoenixville
2021 Ranger Tremor
Printing
Anyone with an xlt that cut the vent out have before and after pictures? Trying to decide if I want to cut mine or not. Wonder how hard it is to remove the dash pad.
