Baja Designs S1 | Over 2k Lumens from a single LED light
Baja Designs
Gold Sponsor
Baja Designs
San Marcos, California
2018 Silverado H.D.
Designed from the ground up our new S1 fills the shoes of a large light in a small package! The S1 utilizes a highly specialized reflector and LED combination to outshine the competition. With the 2.1" length, width, and height the S1 is highly versatile for any application that is in need of light. Whether you're looking for a light to drive off of, or something to light up a campsite the S1 will exceed your expectations!
Specifications:
Lumens: 2,375 Utilizing 1 LED
Wattage/Amps: 20W / 1.45A
Dimensions: 2.1" x 2.1" x 2.1"
Weight: 0.4 lbs
LED Life Expectancy: 49,930 Hours
Front Lens: Hard Coated Polycarbonate
Housing: Hard Anodized & Powder Coated Cast Aluminum
Bezel: Billet Machined Aluminum
Hardware & Bracket Material: Stainless Steel
Exceeds MIL-STD810G (Mil-Spec Testing)
Built-In Overvoltage Protection
IP69K (Waterproof up to 9ft & Pressure Washable)
IK10 Compliant (Mechanical Impact Testing)
CLICK HERE
Advertisement
Baja Designs
Baja Designs
Gold Sponsor
Baja Designs
2018 Silverado H.D.
  • Thread starter
  • Thread Starter
  • #3
Apply coupon code BDForums to save 10% on a Single or Pair of S1's!!!
Single pricing starting at $109.95 before the discount is applied
Pair pricing starting at $208.95 before the discount is applied
Check it out!
Dredgerie
Greg
Nevada
Magnetic Ranger Supercrew
Check it out!
Are you guys going to do the S1 Spot in Amber?
