Baja Designs | 2019 Ford Ranger | Plug and Play Fog Light Kits
Discussion in 'Lighting' started by Baja Designs, May 7, 2019.
  1. Baja Designs
    Gold Sponsor
    First Name:
    Baja Designs
    Vehicle(s):
    2018 Silverado H.D.
    Apr 29, 2019
    San Marcos, California
    62
    These OEM fog light replacement kits are one of the simplest and cleanest options to upgrade the lighting performance of your Ford Ranger. This kit comes with everything you need to make a quick and painless upgrade to your truck, with no cutting, trimming, or fumbling with the wiring. The plug and play connectors fit right into your factory plugs, allowing you to maintain control with your factory hi/lo switch.
    Squadron Sport Kit | total of 6,300 lumens
    Squadron Pro Kit | total of 9,800 Lumens
    These two kits will ensure you can see anything that lies ahead, while also being more visible to other drivers.
    Prices starting at $324.95
    Enter coupon code: BDForums to save 10% + have the option for $5 shipping to the Lower 48 !!!
    Comment below if you have any questions!
    Baja Designs
    www.bajadesigns.com
    coblueberryranger likes this.
  2. OP
    Baja Designs
    Gold Sponsor
    First Name:
    Baja Designs
    Vehicle(s):
    2018 Silverado H.D.
    Apr 29, 2019
    62
    Squadron SAE | UPDATE
    I wanted to post an update on the Squadron SAE. There was a delay in receiving LEDs for these units and we aren't able to receive production quantities until late July. The good news is Amber was approved and we will be offering White and Amber lighting upon release.
    ETA has been moved to Late July / Early August. I'll post more updates as we have them
    PRE-ORDER COMING SOON
    Baja Designs
    www.bajadesigns.com
  3. OP
    Baja Designs
    Gold Sponsor
    First Name:
    Baja Designs
    Vehicle(s):
    2018 Silverado H.D.
    Apr 29, 2019
    62
    Order your Ranger Lighting Kits today and save big!
    Coupon Code: BDForums takes 10% off your order and gives the option of $5 shipping to the Lower 48
    Apply at www.bajadesigns.com
  4. Guinness
    Guinness Active Member
    First Name:
    Nick
    Vehicle(s):
    Ranger FX4 Lariat
    Apr 9, 2019
    San Diego
    42
    Occupation:
    Question about the Squadron plug-and-play kits: I see the SAE kit lists "up to 150% more output than OEM", is that 150% vs. Halogen fog or LED fog? The IIHS results include a distance chart for at least 5 lux illumination, do you (or will you) have a similar chart for the Squadron SAE, Sport, and Pro with straight line and cornering? That would be a very useful comparison.
    Link: https://www.iihs.org/ratings/vehicle/ford/ranger-crew-cab-pickup/2019#headlights
  5. OP
    Baja Designs
    Gold Sponsor
    First Name:
    Baja Designs
    Vehicle(s):
    2018 Silverado H.D.
    Apr 29, 2019
    62
    Up to 150% is mostly referring to the halogen fogs.
    LED fogs won't see as high of a percentage. It does come down to the specific application.
    Some factory fogs are better than others
  6. OP
    Baja Designs
    Gold Sponsor
    First Name:
    Baja Designs
    Vehicle(s):
    2018 Silverado H.D.
    Apr 29, 2019
    62
    Baja Designs offers Vehicle Specific Kits for Trucks, Bikes, UTVs, SUVs, and more. These are designed to plug directly into the factory wiring and provide a significant performance increase. Some replace the factory fog lights and others replace headlights.
    Note: We do offer a few kits that require some extra wiring
    Order a kit today!
    www.bajadesigns.com
  7. RoadBoss
    RoadBoss Well-Known Member
    First Name:
    Travis
    Vehicle(s):
    Apr 6, 2019
    Denver
    105
    122
    Occupation:
    Driver
    do you have any options for the XL rangers without factory fog lights?
  8. OffroadAlliance
    Diamond Sponsor
    First Name:
    Vehicle(s):
    2019 Ranger, 2018 Raptor, 2018 Tacoma TRD Pro
    May 19, 2019
    Brockton, MA
    The plug and play kits are designed to work with OEM fog lights/openings. With a little bit of cutting, running a wiring harness, etc, you could definitely make it work.
    RoadBoss likes this.
  9. OffroadAlliance
    Diamond Sponsor
    First Name:
    Vehicle(s):
    May 19, 2019
    Brockton, MA
    The mad scientists over at Baja Designs just unveiled the latest creation, the Baja Designs S1. This small but mighty light packs a serious punch in a very compact housing.
    At 2.1" x 2.1" x 2.1", it's a small footprint with an huge output of 2,375 lumens! Retail, $208.95/pair and $109.95/single. We have secured the entire first production run quantity of these so if you want a set, we've got them!
    We've already got these up on the website! Forum member discounts of course so contact us today.
    Website for Pair ---->>>> OFFROADLLIANCE.COM
    Website for Single ---->>>> OFFROADALLIANCE.COM
    Specifications:
    Lumens: 2,375 Utilizing 1 LED
    Wattage/Amps: 20W / 1.45A
    Dimensions: 2.1" x 2.1" x 2.1"
    Weight: 0.4 lbs
    LED Life Expectancy: 49,930 Hours
    Front Lens: Hard Coated Polycarbonate
    Housing: Hard Anodized & Powder Coated Cast Aluminum
    Bezel: Billet Machined Aluminum
    Hardware & Bracket Material: Stainless Steel
    Exceeds MIL-STD810G (Mil-Spec Testing)
    Built-In Overvoltage Protection
    IP69K (Waterproof up to 9ft & Pressure Washable)
    IK10 Compliant (Mechanical Impact Testing)
Share This Page
