You're punking us... right?So I decided to finally mod my truck!
I removed shocks & cut my springs! I cut about at half length.
I like it low but the ride is not so good anymore?
If I buy bilsteins & cut those will my ride improve?
Thanks for your helpful advice.
Add some olive oil.I put diesel in because I read on the internet you get better mpg.
My truck is not starting, any recommendations?
Pull your head out of your ass?I put diesel in because I read on the internet you get better mpg.
... Used McDonalds fries oil.Add some olive oil.
You should test these out and see if that evens things out I'm very sure this will solve the rough ride! Good luck!So I decided to finally mod my truck!
Good for climbing stairs.You should test these out and see if that evens things out I'm very sure this will solve the rough ride! Good luck!
Ya, got to switch over to glow plugs. Get the ones that say “turbo ready” and should be good. ?I put diesel in because I read on the internet you get better mpg.
Pure Diesel is too thick for our engine. You need to mix in a quart of vinegar to soften it. Since you already put it to tank you need either drain the tank or add another quart of baking soda to create foaming which will mix the vinegar with the diesel.I put diesel in because I read on the internet you get better mpg.
