Audio Install Issues with For-Ck11
Sanchovia
Tim
SA TX
2020 Ford Ranger XLT
Combo Welder
Help! I have an echo issue with my audio.
for-Ck11 T harness used
Audio Control D6.1200 DSP
I’m running my own speaker wires from the amp to each speaker due to upgraded speakers requiring 200W each.
I soldered my 9 wire and matched the colors to the harness. With running my own speaker wires i capped the other end of the T harness, should i solder these into my 9 wire as well or leave them capped?
pictures in the morning will be added
Sanchovia
Sanchovia
Tim
SA TX
Combo Welder
Update, Starting tuning and my Rears are not Sounding like my fronts, they sound muffled? or tunneled? if that makes sense. went into Forscan and flattened the EQ this helped quite a bit but not fully
That_one_Ranger
Landon
Elko Nevada
2022 ford ranger 2004 ford ranger 1998 ford ranger 1993 turbo IDI yamaha R1,R7
Millwright
Always tune with no eq adjustments generally my rears are slightly quieter as well I think mostly just how the door panel sits around them is just a bit different not familiar with that harness but is I just echoing or creating a high pitch?
Superspirit
earth
22 ranger
I have used that harness in my Ranger and my Mustang, never had a problem. I flattened the eq curve with forescan and incorporated audio dynamics dsp's in both. Running jl audio 75w/ch amps. Alpine subs and amps. Jl audio c1 speakers in the Ranger and morel's in the mustang. I have no echo's or weird sound what so ever. Just great sounds!
