Are Lariat LED Headlights Adjustable?
OUT4DUX
Matt
Washington
Construction
So after my leveling kit and larger tires I am really getting tired of the constant flashing from my fellow road warriors. I have read how to adjust in the owners manual (which incorrectly shows multiple adjusters one for high beams and one for low, which the LED is a single bulb)and on this forum, but no matter how much I turn the adjustment screw my lights simply do not move. Anyone else run into this?
Adventure Ranger
Saskatchewan, Canada
2020 Ford Ranger Lariate Crew Cab FX4 Sport
Heavy Equipment / Truck shop Foreman
The adjusting screw is an 8mm(5/16) hex head mounted near the top of the headlight, on the back side. You can easily get at them with a 1/4" ratchet and socket. If I remember correctly, clockwise lowers the headlights. They move very slowly, I wound up cranking mind down 3 full turns after my level kit.
OUT4DUX
Matt
Washington
Construction
The adjusting screw is an 8mm(5/16) hex head mounted near the top of the headlight, on the back side. You can easily get at them with a 1/4" ratchet and socket. If I remember correctly, clockwise lowers the headlights. They move very slowly, I would up cranking mind down 3 full turns after my level kit.
Yeah that's the one I have been turning with nothing. Clockwise 20 times and nothing ever moves. I have my headlights on aiming at the shop and there is simply no movement in either direction
jusknight
Justin
2019 Ranger Lariat Supercab
Thanks Mike! I get the same flashing lights from oncoming traffic all the time! May have to give this a shot!
One life live it
Randy
Halifax NS
2016 Jeep JK 1985 (2008) Landrover Defender 110
HI Ranger owners, I have the same problem with my 2019 Lariat LED lights.
I don't carry much weight maybe 500 pounds of gear in the bed when going to the off grid campage. I've been disappointed in the flash from other drivers. I will try to adjust them if not to the dealer. If I'm pulling the side by side I put the load equation bars on and force the front end down.
Thanks for the information. Only had the truck (blue berry) for about 3 months.
Only upgrade is the ford power bump.
Obijack
J J
NE Florida
2020 Ford Ranger Lariat FX4 iconic sliver
Attorney
I’d post a pic of the screw you are turning that isn’t adjusting the headlight to make sure you are turning the right one. I keep a 8mm gear wrench combo wrench in my glove box for adjusting the lights. And it is very quick and easy.
cfhgarza
Ohio
2020 Magnetic XLT 301A
Press and weld set-up
If they were already all the way down and you tried adjusting more it's possible that the adjuster broke.
MXGOLF
Lucille my 2020 Ranger Lariat 4x4 -2007 Yamaha FZ6
Sales / Photographer
I am assuming that it's the same for the 2019 and 2020 Ranger Larait?
Thanks,
