ARB front bumper questions
MrBusses
2019 Ranger 4dr FX4
Ford SMT
Looking at getting the ARB front bumper and I have a couple of questions for those that have them.
First question is winch compatibility. I have a 9k badlands winch will it fit?
Second is I have front parking sensors, I know it says its not compatible but I am wondering if the the BCM reprogram disables it or would I need forscan for that? I am a ford tech so I have FDRS so programming isnt an issue just wondering if FDRS does that or if I will need forscan
Thanks in advance
Colo_Ranger
Glocker
Boca Raton
The other winch bumper has front parking sensor mounting points and relocation brackets for the cruise control sensor. And I'm pretty sure it'll mount the Badlands winch. (it comes with a winch mounting kit with provisions for multiple winches, but TERRIBLE instructions!)
As for the one you're interested in, good luck! I don't know.
LawnMM
Rich
'23 Ranger Tremor
Thanks in advance
Ruling on the field is yes, if you want to give me a measurement from bottom to top highest point I can check for you.
That said there's significant space between the bumpers rear mounting surface where the winch goes and where you run into the bottom of the AC/radiator/whatever the hell it is
All the BCM is doing, to my knowledge, is altering the airbag deployment timing.
It doesn't have the holes for the sensors but if you put the work in it can be made to happen. Forscan won't do it, I tried, you need FDRS.
MrBusses
MrBusses
2019 Ranger 4dr FX4
Ford SMT
Thanks. I have FDRS so no issues with that. Guess its a decision on if I want to deal with making the holes for the sensors or not. Imagine a decent step bit should make short work of it.
LawnMM
Rich
'23 Ranger Tremor
I used a hole saw and a Dremel to cut the keyways for the sensor sleeves and to trim the sleeve standoffs on the rear bumper sleeve
To make life easier get the ARB Summit Bumper. It has the holes for the paring sensors and probably has room for the winch, that said I would recommend getting a Warm Winch over the Harbor Freight winch
hersh
josh
[/QUOTE
Hey, Did you install the Ford Performance bumper yourself or did you have a shop do it? I'm in CO as well, and have been eyeing that bumper.
