Anyone been having trouble with Apple CarPlay?
GreyThumper
Dino
Philippines
Ford Ranger Raptor, a BMW R1200GS, a BMW R1150R
Sometimes it gets wonky and I assume it's just a dodgy cable and usually things work fine when I use a newer cable. But recently all my cables stopped activating CarPlay (although my phone still gets charged, and I can still play phone audio through Sync). I tried using a friend's cable and iPhone in my vehicle, and his phone activated CarPlay. His is a 12, my phone's an older XR, but both are on iOS 14.6. Weird. I wonder what I can do next to troubleshoot and figure out how to reactivate CarPlay.
lawrench
Harry
2019 Ford Ranger Lariat SCrew FX4 Lightning Blue
That sounds like a phone issue. I do not like the whole Apple eco system. But they have had issues with their antenna's in the past, maybe a weakness in your hardware version and a new(er) phone may be the best solution.
TremorOwner
2021 Ranger Tremor
The iPhone port is designed to fail. But you also might check inside the port to see if there's lint or anything inside. I had lint once, same symptoms... picked it out, good as newski.
XFlyer
Bo
SK,Canada ??
Ranger 4x4 super crew Lariat
Hickesy
Mine's never worked, I gave up. Waiting until I take it in for an oil change....iPhone 12.
GA
Since I carry mine in my pocket, the charging port fills with pocket lint.
I have to regularly clean out the port with one of those plastic toothpicks or I get weird connection issues.
XFlyer
Bo
SK,Canada ??
Yes my phone is a 12 as well, yesterday it work for three hours went for lunch and …no Carplay. No matter what I did rebooted the phone stopped the truck shut it down and restarted ,nothing, but the phone is charging! This morning all was fine again.
JesseS
Jesse
NorCal (Roseville)
My iPhone X works fine, both tethered and wireless (I have a wireless adapter), I did have to get a newer cable as the one I was using was really old.
JesseS
Jesse
NorCal (Roseville)
Thanks, I was having that issue also, and the setting is buried deep in IOS 15.2 so I didn't see it.
I rebooted my phone a 7+ and works sometimes. Changing the USB Jack position has done it other times. I think it’s a SYNC issue with the last update. Before that never had a problem with it
Texasota
Al
Rochester, MN
2020 Ranger XLT, 2023 Escape PHEV
