Wannabe_spek
Did you pull the cover? Is it 32 like arb states in my last comment? Hope this works i want that lsdI'm about ready to pull the diff cover, check the spline count, take some basic measurements and check the ring gear.
I've read the ring gear is welded to the carrier and want to verify.
If so, I'll probably order a set of 4.1:1 gears with the lsd if the spline count is really 32.
With the tire size, the lower ratio is not unreasonable and with an lsd, should really liven up the initial acceleration experiance. Yea, a hit in highway fuel economy but with the 10 speed transmission, probably little impact around town if the go pedal is used judicially. (Big IF!!!)
