Amp Research Power Steps
If they’re made out of aluminum a new carbide circular saw blade on a chop saw will give you nice clean square cuts. Just let the blade cut with minimal pressure. Clamp if you can. If steel different approach entirely
BobKnake1968
Murfreesboro TN USA
2020 Ranger XLT supercab 4x4 Sport
RN
was kind of thinking about that too
With way, need to get a new blade for the chop saw
I have some background in metal work matching in the family machine shop several years.
Get blade wax too! Just a little bit keeps the aluminum from sticking to the carbide. As they say, a little goes a log ways.
BobKnake1968
Murfreesboro TN USA
RN
Chop saw
Carbide blade and a little blade wax
done cutting With the chop saw before I could have ever started with the hack saw.
BobKnake1968
Murfreesboro TN USA
RN
Installed
Video needed tucked away.
HenryMac
Mech. Engineer - Retired
im thinking that stepping on the end towards the bed would not support the weight properly - and potentially bend.
I’ll be getting a new blade or 2 tomorrow and follow the directions
Because why? It's designed to handle the weight for folks that have a SuperCrew.
That would have been awesome for reaching the front bed tie downs from outside the truck. I'm guessing they want it trimmed because they are worried about the bed moving independent of the cab? But based on member photo's here on Ranger5g.... that's not an issue.
So how do they look from a distance? Do the brackets hang down and are visible?
Toronto, Ontario
2019 XLT SuperCab
Husband-Caregiver
Chop saw
I’m so glad you went that route - I use my DeWALT mitre saw on aluminum deck railings, etc. with a blade designed for fine finishing work - 96 teeth, I think. I was about to suggest you use this method and then I saw this photo - nice!
BobKnake1968
Murfreesboro TN USA
RN
It was like cutting through butter.
Now I just need to get my bigger tires.
Toronto, Ontario
2019 XLT SuperCab
Husband-Caregiver
I know just how you were feeling as you lowered the blade, started making that first cut and the saw DID NOT kick back. The first time I tried it, I went from nervousness to relief, surprise, and then, absolute glee. Good job - it looks like BobCanBuildIt too! ???‍♂?
2020 Ranger
Alan
Richlands, NC
2020 Ranger
Retired U.S. Marine
hi anyone put power running boards on there Ranger yet .iam taking off my factory ones tomorrow and having canopy world in Bremerton wa put power running boards on . will sell my factory ones
Yes, I put AMP on and they work great
Phessor
Arizona
2019 Ford Ranger 4x4 XLT Crew Cab
Has anyone added the powerstep override switch?
dguffin
Dana
Aberdeen, SD
20 Corsair, 19 Ranger, 12 Boss, 08 Zuma
Shop Foreman
I added it during the install. I use it when going threw certain car washes, or when I want to clean them manually at home. Nice feature.
Phessor
Arizona
I installed a set of powersteps on my 2019 Ranger and I want to add the override switch. But I am am confused as to which switch kit to get. Do I just need the basic switch/wiring harness kit?
I have emailed Amp Reserach asking this question with no reply.
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
I ordered my powersteps from Electric Step, and included the override switch with my order. They sent the switch with model number 79106-01A, which worked perfectly with my steps. My steps were model number 76136-01A, which I believe is the only option available for the Ranger. Mine's also a '19.
Good luck!
