Advice for new Ranger owner
LiftMyRide
George
Denver colorado
2021 Ford Ranger XLT
Assistant Manager
Hi im new here and also i have never lifted or put a leveling kit on a truck before either. I have a 2021 Ford Ranger XLT Sport Super Cab. can anyone recomend a leveling kit ( under $300 ) that i could install myself ?
Im not a heavy off-roader but i do hunt a lot so a little more ground clearance, a beefier tire and get rid of the rake from the stock truck.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Welcome to the forum. I have the Rough Country 2 1/2" level lift . It is a spacer that fits on top on the front stock coilover. A friend with a shop, did the job and aligned it .
Leveling kits are not a good idea if you plan to lead the rear. There is a reason for Take, simple as that. As a suggestion take the truck to places you plan to go first and evaluate from there. The Ranger is very capable as it is and there.is a chance you may not have to do anything.
ljames
Larry
Phoenix, Arizona
jameselectronics.com
2020 Ranger 4x4 FX4, 2011 CRV,1998 Ford E250 super
contractor
advise: leave it stock
I have the same truck as you. Mine is still stock rake after 2+ years of ownership. If I did level it it would be because I’m upgrading the shocks because I want a firmer ride. That for me is an eventuality. Stock shocks only last so long and the wallow of the truck will just make me want to ditch the stock ones all that much sooner! Then you get level for a bonus
LiftMyRide
George
Denver colorado
Assistant Manager
ar you running 255 65 r17 or have you gone larger ?
thinking of going with the Fox 2.0 front and rear if i can afford that and installation + tires
I’m still on stock tires as well. Will probably go same size or slightly wider when I get new shoes on her. I was going with Ford Performance Fox shocks 2.0 if and when I pull the trigger. Better suited for my needs. I will do all 4 when I do upgrade though.
Mustang2Ranger
Garrett
Southern California
Yea if you want to stick under $300 the RC spacers are a good deal at $100 new
If you do it yourself then you just pay that, and for alignment
I have a used pair for sale if you want to send me a message, I upgraded to Kings so they are just laying around
Burnt Money
Andy
Charleston SC
2020 Ranger XLT FX4
I have the Rough Country 2.5in/leveling coil overs. They were 350ish I think from Stage 3 Motorsports. They are a site sponsor so you can PM them for a price. I was in the same situation. I don’t do anything crazy off road like the guys that live near mountains. Mine is all logging roads and swampy areas hunting. So far they have held up fine with no issues.
LiftMyRide
George
Denver colorado
Assistant Manager
are you noticing any squat after putting in your leveling kit such as if you put a 4wheeler or a deer etc into the bed ?
SilverSlugger
Wally
AZ
2019 Ford Ranger Lariat FX4
Baking
I put Fox 2.0 combined with 275 65 18 tires, I like that combo a lot.
rydfree
Benny
Maintenance
2019-2022 Ford Ranger 2.5" Front Lift Kit – Torch Off Road
I have the Torch off-road 2.5" kit with 32" 275/65R18 Wildpeaks and have been very satisfied. Found the kit on Amazon for $79 . No hard off road stuff but my property is rough in areas and it has been fine . I've had 600lbs of sac-crete in the bed with no noticeable squat and have towed my 16' trailer with tractor/backhoe loaded and had very little squat.
