Adding a switch to turn off DRL?
JACKSMYDOG
Jay
Ontario
2020 Ranger Lariat FX4 Black
I'm adding a few different lights up front, and all will meet DRL requirements. I'd like to be able to switch off factory DRL and run just amber DRL with a simple 2 wire switch in the cab. Any recommendations where/how to locate the DRL wires in the cab without having to go through the firewall? It's a 20 Lariat FX4. Thanks :)
I believe you can go into the dash menus to turn off DRLs. You can also use Forscan to change what lights come on for DRLs. In my XLT I use fogs and parking lights, not low beams.
FoD
Terry
Out There
2019 Ranger XLT FX4 Chrome Iconic Silver
COO of Dave's DeeZee Enterprising
I have seen/done that in Forscan and there are several options for what is on/off to choose from if you go that route.
JACKSMYDOG
JACKSMYDOG
Jay
Ontario
Thanks, in Canada I think they are mandatory on vehicles now, so there is no option in the menu. Lights timer, and auto high beam only.
Also thanks, going to look at FORscan now. I've seen in mentioned here a few times.
Rviator
FLA
retired aerospace engineer
With a Lariat you can go into the menu and turn off the Automatic On headlight feature to disable the DRL's.
TremorOwner
2021 Ranger Tremor
Where can I find Forescan instructions? The fact that the XLT trim has the headlight with less voltage as the DRL is so year 2000 that I want to scream. I'd love to change the DRL to something else, like the amber turn signal.
