Actual fuel left in tank
Travis11
2019Tacoma
Does anyone on here know how much fuel is actually left in tank when vehicle shows empty. The Tacoma I know had 3 gallons left in at empty. This is my first tank of fuel and I was trying to compare the two. Any info is appreciated.
joeb427
I don't there's much. I was at on screen 30miles till empty warning which starts at 50 miles to empty and it took just over 17 gallons with an 18 gallon tank capacity.
Travis11
2019Tacoma
Okay, that’s what I needed to know; would be better to fuel up at 1/4 of a tank then so fuel pump will stay submerged.
joeb427
I usually fill ay 1/4 tank too but wanted to see when the fuel light comes on and it's not the usual light. It's a 50 miles to empty pretty large warning on the dash left on a Lariat.
HenryMac
Mech. Engineer - Retired
When we picked up our truck at the dealership the "Miles To E" display showed "0" miles of fuel remaining, and the out of fuel chime was ringing.
We drove about 3 blocks and filled up the tank.
It took 18.524 gallons before it shut off the pump. Fuel capacity per page 319 of the owners manual is 18.8 gallons.
18.8 - 18.524 = 0.276 gallons remaining.
PNW_Ranger87
Erik
Renton, WA
2019 Ranger XLT 4X4
Parts Specialist
I've been filling up with about 50 miles DTE showing and have struggled to get 16 gallons in. I feel like it's more like 75-80 miles to E for me. I obviously like to be more prepared than not but my range has suffered compared to others on here it seems. I'm only on my 4th tank of fuel though. I wonder how much more calibration/learning the DTE system will do...
khyros
2019 Ford Ranger Lariat Crewcab FX4
I got my truck down to 4 miles to empty, and put 18.1 gallons in the 18.8 gallon tank. That tank had averaged 22mpg, so the .7gal remaining represents 15 miles, so 11 miles / half a gallon once I hit 0 miles to empty. As a disclaimer, I have gone through and adjusted my fuel economy modifier to be more aligned with reality, so my MPG number is lower now that it was from the factory (and actual FE is still lower if I do city driving, but higher on the highway).
MT19RANGER
JERRY
SIDNEY, MT
Your dealer didn't give you a free tank of fuel... that's just not right... every vehicle I've bought in the past get's a free fill up.
joeb427
i have driven several times below 10km remaining.
not even abrupt cornering made a difference.
but the comment above, about keeping the fuel pump submerged....why is that an issue?
I would think it keeps the pump cool.
Lunchbox88
Logan
Missouri, USA
2019 Ranger SuperCrew FX4
Fuel pumps are typically cooled by the fuel. If the pump isnt submerged anymore the pump could get hot and lead to a premature failure.
PNW_Ranger87
Erik
Renton, WA
2019 Ranger XLT 4X4
Parts Specialist
The fuel pump is also cooled by pumping fuel though it. Running low on the tank is not nearly as bad as running out of fuel completely.
joeb427
Travis11
2019Tacoma
Exactly what lunchbox88 said. Very simple way to help the longevity of your fuel pump is to fuel up with at least 1/4 of a tank of fuel left to keep your pump submerged.
joeb427
khyros
"The fuel pump in this video was removed from a 2001 Toyota Corolla." -Youtube description of the video Jalopik is referencing.
And from the article itself:
"In addition to overheating and prematurely wearing out the pump, running a car low on fuel tends to pull up the sediment that normally sits at the bottom of the tank. (This is a bigger issue with older metal gas tanks that tend to corrode, especially when empty and thus exposed to moisture in air.)"
