Chmatisello
- Thread starter
- #1
Will 275/70/17 general grabbers fit without rubbing I have a 2.5 in level installed
On factory wheels, maybe. I have that size in a KO3 but i also threw a 30mm spacer on and needed to swap to the ready lift high clearance crash bars.Will 275/70/17 general grabbers fit without rubbing I have a 2.5 in level installed
Is your speedometer slow by about 3 MPH?Will 275/70/17 general grabbers fit without rubbing I have a 2.5 in level installed
Just a side note, the grabbers that came on my tremor seemed to pick up every little pebble and would throw it anywhere and everywhere.Will 275/70/17 general grabbers fit without rubbing I have a 2.5 in level installed
All theories and math aside...putting them on is the only way you'll find out what's rubbing what if anything...everyone's combinations is slightly different...I have 285/70-17 Grabbers and no one has my combination of wheel offset + spacer + level...I haven’t put the tires on yet so I’m unsure
Grabbers drove me crazy with this, drive down a dirt road for 5 min and be flinging rocks on the highway for 30 min. Also they were bad in any type of wet condition. I'd have to baby the throttle or else traction control would kick in all the time.Just a side note, the grabbers that came on my tremor seemed to pick up every little pebble and would throw it anywhere and everywhere.
That was just my experience, I moved to KO2's and havnt had as much pebble throwing, but I have noticed in that they dont handle the the snow/mud as well. Your millage may vary, because I also live in Utah.
with 285/75 I am 6mph slow reading, until I can hook up the forscan to change itIs your speedometer slow by about 3 MPH?
Forscan was able to adjust mine to within 1 mph...with 285/75 I am 6mph slow reading, until I can hook up the forscan to change it
Lights don't count..... Just sayingAll theories and math aside...putting them on is the only way you'll find out what's rubbing what if anything...everyone's combinations is slightly different...I have 285/70-17 Grabbers and no one has my combination of wheel offset + spacer + level...
Yeah, my ranger is 3 MPH slower after 30 MPHwith 285/75 I am 6mph slow reading, until I can hook up the forscan to change it
