265/70R18 K02s w/ 2.5" level kit (stock wheels)
Xevo
Calgary, AB
2020 Ranger FX4 Lariat
Long time lurker, first post. Just managed to squeeze some 265/70R18 KO2s on my truck with only a 2.5" leveling kit. I scoured for days to see if this would work without adjusting crash bars and couldn't find an answer as everyone seems to use 17" wheels. I took the chance on them and gave it a shot. Just wanted to let the next guy know that it works without any rubbing.
TJMarchand
Trevor
Medford, MA
Looks great, and KO2's look fantastic. Which lift did you go with?
Xevo
Xevo
Calgary, AB
Awesome, I ask everyone but have you noticed your mileage suffering a lot?
I haven't gone far enough to measure yet. I'll be doing a road trip in a couple of weeks, then I'll be able to report back.
Toronto, Ontario
2019 XLT SuperCab
Husband-Caregiver
RecoilOperated
Albany, New York
2020 F-150 XLT, 2022 Subaru Outback
ICU Nurse
Is the level necessary or do you think you could get away with this tire size on stock ride height?
MoatCarp
Nathan
Houston, Texas
2019 Ranger Lariat FX4
IT Systems Administrator
Looks great! I've also got OEM 18" wheels and am shopping tires.
With the lift, do you think you could go any larger than this on the tires before rubbing? Or do you feel that's pretty close to the limit?
Jrel209
Wa
2020 Ranger XLT crew cab
Looks great, im right behind you and finally pulled trigger on fox2.0 stage1, i should have it installed by next week. The ko2’s or falkens in same size will follow next month haha.
Xevo
Xevo
Calgary, AB
I don't think you can do any more than this. From what I've been reading, I went very slightly larger than what others have been doing. This is pushing it for sure
Brett Fields
Brett
Brooklyn
2021 Lariat FX4, Blackout, Tow
Paramedic
Can you describe the ride feel difference with the stock fx4 suspension and the taller tires?
Pirate
AK
Bush Pilot
I went through the same trials and tribulations. Not easy spending $1k on rubber not knowing if it will fit. First picture is stock suspension with 265/70/18 Wildpeaks. Second picture is with the Fox 2.0 kit installed. I had very slight rubbing somewhere on stock suspension. No issues once the Fox kit was installed.
