nanohead
- Thread starter
- #1
About a 6 weeks in to my 2021 Ranger. Bought an XLT FX4, and have mostly been enjoying it....mostly. Have about 4000 miles on it
I've read a ton on this forum and there's lots of knowledge, so figured I'd post some impressions so people can opine on what I can do about some of these things.
FWIW, I didn't really want the FX4 Off Road package, but as inventory is pretty light these days, I took what I could get, as my rusty 2008 Dakota decided it just wanted to disintegrate.
Any thoughts on engine/trans/suspension/braking are welcome....
- Engine: Test drove the Ranger, so knew what I was getting. The engine itself has adequate power for the weight of the truck. The programming is basically decent on the engine, but clearly there is more that can be gotten from it. Will likely try the Ford tune. The lugging at low speed is not optimal but I think the trans is mostly responsible.
- Transmission: Hardware is fine basically, but software is pretty awful. The programming is oriented toward fuel consumption and emissions obviously, but it doesn't really succeed. It is hyper aggressive at upshifting, and maintaining higher gears, even at low speeds and especially when decelerating. At low speeds in traffic, the truck lugs, and the body shudders. And on deceleration, the trans gets confused if you need to accelerate again. Its goofy, but not that different than other multi speed transmissions we have that had conservative programming. Possible that the Ford tune could improve this.
- Brakes: Not sure if they are not big enough for the truck, or the pads are too soft, or its something else, but they definitely struggle to slow the truck down, especially if you need heavy braking. They feel squishy when I brake aggressively. Combined with the the trans shuddering on braking, the whole truck feels like its shaking heavily. And braking heavily when turning, like on a exit ramp, is just unpleasant. Not sure what to do here. The tires could also be a culprit
- Suspension: I didn't really want the "off road" FX4 package, but its what they had on the lot, so I took it. The truck, especially the front end, bounces all over the place. Definitely tuning and damping for off road. The tires, Hankook ATM are just not my cup of tea. Super squishy, probably fine for off road, but I'll never really do that. So I think I'll just replace them. The spring/dampers are another story altogether. I'd prefer that the truck turned better and had more precise steering. It could be that tires alone would dramatically improve turn in and general handling. I've already had 1 catastrophic blowout with one of the Hankooks and had to replace it. I probably should have done all 4 with a regular all season road tire.
- Audio: I'm a pathological car audio hacker. Its a bad disease. I think the audio gear in my last pickup was worth way more than the rest of the truck. I can't wait to start replacing and upgrading. Trying to find a T Harness that will work with the 2021, all the one's I've found are good for 19-20. I might just make my own.
- The front doors: OMG, they sound like tin cans, its embarrassing. Nothing a bunch of Ensolite and sound dampener can't fix.
