2020 Ranger Shackle replacement?
Tom_C
Tom
Virginia, USA
System Admin, Retired
Hi All. I’m not new to trucks, I had a ’93 Toyota 4x4, a few years before the Taco. I just bought my 2020 Ranger Supercab Lariat FX4 as my daily driver to prep for retirement in the mountains of WV. I love it, though I’d like to smooth out the ride a bit of an unloaded box.
Is there anything that can be done as a substitute to the Sulastic leaf shackles that aren’t available for the 2019-21 Ranger? I’m not interested in doing any lift or changing tires. Would just like to ‘soften’ the ride a bit in the rear end.
I have read through the forums and done internet searches without much success.
DrizzyDrake
Drake
Calgary AB
Legacy GTB, RX7 FD, soon buying a ranger
Technician at Subaru
Best bet for fixing the rear is struts
kieefer
keith
Remove the overload springs.
Tom_C
Tom_C
Tom
Virginia, USA
Thanks. So, with the information about struts, I was able to find several threads about it. Seems a common brand is the Fox 2.0? Looks like a fairly cheap upgrade.
Are there any significant differences between Fox and other brands? Will continue to look for other threads so sorry if this is rehashing old info.
Tom_C
Tom_C
Tom
Virginia, USA
Thank you, I forgot to mention that my tires are all set to 40lb as from the dealer. I've seen some people say to go lower, some higher. Guess I just need to test it myself?
Tom_C
Tom_C
Tom
Virginia, USA
Copy, thank you. Cheapest upgrade of all :) I will check it later.
VAMike
2019 Ranger Lariat SuperCab
Just look at the door sticker. Different options come with different tires, Ford had already tested them all. Dealers just don't bother to look at the door sticker.
Tom_C
Tom_C
Tom
Virginia, USA
Thanks all. I lowered the tire pressure from 40 to 34 and it rides much better. Door sticker says 30 so I will lower down to 30 when the tires cool down. Appreciate the info. I will eventually swap out to different struts, but it's much better now.
