Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
In stock and ready to ship
(1" spacers are out of stock and dont have a set ETA at the moment)
2019-2022 Ford Ranger FactionFab 6x139.7mm 1.50" Forged Aluminum Wheel Spacers in a Set of Four FFA1.10220.1X2
Highlights:
Whether you're hankering to clear wide tires on high-offset wheels with awesome suspension upgrades or just want a wider stance for your 2019-2022 Ford Ranger, the FactionFab 1.50" Billet Aluminum Wheel Spacers are to help. This set of four high-quality wheel spacers allow you to give your Ranger the perfect stance and the clearance you need to run the wheels, tires, and suspension you've been craving all in a high-quality package that won't let you do both on and off the road. Both of the spacers in this kit are made out of high-strength forged aluminum that's flawlessly machined for a perfect fit on your Ranger. The spacers come standard with strong, steel studs, flanges for hub and wheel bore, and tapered lug nuts to provide excellent force distribution. FactionFab's Spacers are right at home for both street driving and aggressive off-roading in nearly any application you have in mind.
Forged Aluminum Spacers with a Black Anodized Finish and 12.9 Steel Studs
FactionFab builds each of these spacers incredibly strong so that your Ranger can go anywhere and do just about anything without fear. Each wheel spacer is manufactured out of forged 6061-T6 aluminum that's then machined down for your Ranger's bolt pattern and hub bore to maintain the high yield-to-strength ratio of the aluminum. The spacers are then fitted with grade 12.9 studs with an OEM 12x1.5" thread pitch and a corrosion-resistant Geomet coating that keeps the studs in excellent shape in nearly any climate or application. The spacers come standard with grade 8.8 open-end lug nuts that likewise have a Geomet coating. The lugs have a tapered seat that works with the chambered holes in the spacers to make installation easy and provide near-OEM force distribution. The spacers are topped off with a black hard-anodized finish with laser-etched lettering that gives them a great look and further protection from corrosion.
Set of four Spacers: this part number is for a set of four spacers. A version of this kit with just two spacers is also available.
May not be legal for street use: these spacers may not be street legal in some states (namely Pennsylvania and Massachusetts). Please check your local laws before ordering.
Highlights:
- Extremely strong, high quality wheel spacers
- Forged aluminum construction
- High-grade steel studs and lug nuts
- Black hard-anodized finish
- Designed for stock hubs and hub bore wheels
- Set of four 1.50" spacers
