Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
2019-2022 Ford Ranger CURT Class 3 Rear Trailer Towing Hitch with Square Tubing 13417
Highlights:
Whether you use your 2019-2022 Ford Ranger for hauling heavy-duty equipment to and from the job site or for those weekend getaways with your ATVs or camper, you're going to need a trailer hitch receiver that is up to the task. Equipping your truck with a Class 3 Towing Hitch from CURT provides you with some impressive strength for most applications with a maximum weight carrying capacity of up to 6,000 lbs. Class 3 trailer hitches are able to tow most standard size trailers, boat haulers and campers, giving you the confidence to get the job done without stressing out your truck or causing you to white-knuckle it the next time you're pulling a large load. This CURT Class 3 Receiver Hitch includes a 2" tube opening that accepts a ball mount as well as similar aftermarket towing accessories with an equivalent shank. After CURT gives this hitch an awesome-looking black powder-coated finish, it is also co-cured with a rust-resistant Aquence coating to prevent corrosion and keep your truck looking great. This durable and reliable hitch will give you the confidence and safety you need while driving up or down severe grades as well as those times when the road gets twisty or bumpy.
Solid Construction With Exceptional Towing Capacity
This high-quality Rear Hitch was designed to give your Ranger the capability of handling heavy weight loads, earning it Class 3 status. Your Ranger will be set up with strength and reliability for hauling some commercial machinery for work as well as towing a boat or your camper for those weekend getaways. Expertly welded together with super strong steel, this CURT Rear Hitch is precisely welded for superior strength and is protected with a durable high-gloss black powder coat finish and is guaranteed to tow or haul your heaviest equipment without bending or flexing under pressure like lesser quality hitches on the market. Built tough in order to perform during heavy towing and daily hauling, this hitch was crafted with high-strength steel and tested for safety in accordance with SAE J684 ratings.
Fitment: 2019-2022 Ford Ranger.
Details & Weight Ratings:
Highlights:
- Allows for heavy-duty towing
- Carrying capacity of 6,000 lbs
- Uses square tubing design
- Has 2" receiver tube size
- Features black powder coat
- Uses factory bumper/frame bolts
- Class: 3
- Weight Distribution: 8,000 lbs.
- Distribution Tongue: 900 lbs.
- Tongue Weight: 900 lbs.
- Weight Carrying Capacity: 6,000 lbs.
- Receiver Tube Size: 2"
- Finish: High-Gloss Black Powder Coat
