Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
Plenty in stock and shipping today, as always, message me for forum pricing.
Frank
2019-2021 Ford Ranger TurboSmart BOV Kompact Dual Port VR13 TS-0223-1096
Highlights:
Your 2019-2021 Ford Ranger EcoBoost deserves a big, mean, and aggressive sound when all that boost pressure needs to be released, and the Turbosmart BOV Kompact Dual Port VR13 gives that to you. Turbosmart's BOV Kompact gives your awesome EcoBoost Ranger a true BOV operation and sound, and this variant from our friends over at Turbosmart even fits onto aftermarket intercoolers. Just like its predecessor, the Turbosmart BOV Kompact drops right into place of the factory eBOV and comes with everything you need to get it up and running on your truck, all without throwing a CEL. The BOV is less prone to leakage, has rapid response and better thermal performance while handling much higher boost pressures than the stock eBOV, making it perfect for high-powered Ranger builds. Hybrid or large flowing turbos with OE electronic diverter valves will benefit from the lack of leakage; the turbo charger and wastegate will not be stressed by the EM achieving its target boost. The dual port design also vents to the atmosphere and then back into the air intake. Billet Aluminum Construction with Drop-in Design
Each BOV and fitting is made out of CNC machined billet aluminum, which gives it greater strength and durability over the factory plastic eBOV. Just unplug and unbolt your OEM Blow-Off Valve, and install this product in its place. You can do this without adapters, hoses or extra assembly. You will retain OE control of the BOV's operation.
Fitment: 2019-2021 Ford Ranger 2.3L Ecoboost
Frank
Highlights:
- Give your truck a mean BOV sound
- Stronger than the factory eBOV
- Billet aluminum construction
- Uses dual port venting system
- Improves response & thermal performance
