Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
In stock and ready to ship for anyone in the market, shoot me a message for forum pricing.
Frank
2019-2021 Ford Ranger 5ft Bed BAKFlip MX4 Tonneau Cover 448332
Highlights:
One of the biggest problems with most of the folding tonneau cover designs out there is that they're an utter pain to completely remove from your truck and practically require a full uninstall. Well, BAK has a solution to help you load and haul extremely large hardware and gear with minimal amounts of hassles. An all-new integrated buckle system gives you the option to even drive with your cover, folded, flipped up or closed. The BAKFlip MX4 Tonneau Cover for the 2019-2021 Ford Ranger features a folding design that flips up toward your 2019-2021 Ford Ranger's cab to give you access to the bed. The BAKFlip series is extremely strong and lightweight, making it easy to use while being durable enough to handle a maximum 300lbs of evenly distributed weight. The MX4 cover is water resistant due to its effective drainage system; rails collect and move water from the front of your Ranger's bed to drainage tubes. Easy, No-Drill Installation
The matte black BAKFlip MX4 Tonneau Cover was carefully designed to outclass other fold-up tonneau designs by being easier to use while just as strong, durable, and dependable as other tonneau options. It is made out of heavy duty aluminum folding panels which ensures durability and UV/scratch resistance to the elements. The tonneau has an sleek low-profile design that sits almost perfectly flush with your Ranger's bed. BAK's patented latch system is hidden under the cover and ensures that your gear is safe with a simple lock of your tailgate. Remarkably, this tonneau cover features an easy install using a clamp on design and require absolutely no drilling, cutting, or other permanent modifications to your truck. The average install time for this product is only 20-30 minutes!
Fitment: This fits a 2019-2021 Ford Ranger w/ 5 ft. Bed. A 6 ft bed version is also available.
Frank
Highlights:
- UV Protective Matte Black Finish
- Heavy Duty Aluminum Paneling
- Uses Folding Design
- Precise, Rigid Fit for 5ft bed 2019-2021 Ford Rangers
- No Drilling or Cutting Needed
