Mustangski
- Joined
- Dec 18, 2021
- Threads
- 1
- Messages
- 5
- Reaction score
- 1
- Location
- Nomad, everywhere
- Vehicle(s)
- 2021 Ford Ranger STX/FX4
- Occupation
- US Military
- Thread starter
- #1
2009 Schutt Industries M1101 Trailer
Moving and can’t take this with me, looking to sell it. A lot of work already complete on this trailer and makes a great trailer to go anywhere you need to. Everything works, our family has had a lot of great trips with this.
Can't get photos to load, see pics at: https://sacramento.craigslist.org/tro/d/elk-grove-military-m1101-camping/7473036323.html
$10,000 w/tent
$9,000 w/o tent
- 2600 lbs dry / 520 lbs tongue weight (measured with calibrated shipping scales)
- American Racing AR23 black wheels w/matching spare
- Ironman Radial LT235/85R16 Tires
- Custom 2” pintle hitch included that allows level towing of trailer
- Recently re-packed wheel bearings with new wheel seals
- Surge brakes, flushed with new fluid last month
- Converted to 12v, 7-pin trailer harness
- Security: Pintle lock, wheel lock
- Metal top cage w/ removeable center (bolts, not super simple but can be removed)
- Cage sits approximately 75” tall measuring from the ground.
- Brackets welded to side for awning mount (awning not included)
- Highway Products truck slide, lifetime warranty
- Power Tank bracket mounted on rear w/10 lbs propane tank.
- Dual WeatherGuard boxes on each side, lockable
- Rear 2” receiver made from square steel tubing (mount additional rack or bike rack, etc.)
- Water pump/Propane heater
- FloJet electric water pump mounted inside front Weather Guard box
- Powered by battery box listed below
- Camplux 1.32 GPM propane water heater mounted inside pelican case.
- All water and propane connections are quick disconnects
- Leveling jacks/stands
- (2) Front pin adjustable legs
- (2) rear crank adjustable legs allow near perfect leveling
- LED Reverse lights
- LED lighting
- Powered by custom battery box that uses factory trailer wiring and 7-pin connector
- Dual USB Charging port near rear of trailer
- 12v emergency style rechargeable flashlight w/mount
- Fire Extinguisher with rear mounting bracket
- Shovel, axe, tool brackets
- Overland Vehicle Systems (OVS) Nomadic 4 Roof Top Tent
- Tent Comes with Annex
- https://overlandvehiclesystems.com/...an5mbX7udH6OOItFbRhhoTKngX3GcLF0aAiymEALw_wcB
- https://overlandvehiclesystems.com/...nex-green-base-with-black-floor-travel-cover/
$10,000 w/tent
$9,000 w/o tent
