Stage3Motorsports
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 894
- Reaction score
- 1,367
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
Since tire inventory is all over these days figured I could bring some available options to the forums.
LT285/70R17 Falken Wild Peak All-Terrain A/T3W Off-Road Tire F28030612
Rugged & Dependable All-Terrain Off-Road Tire
When it comes down to picking out the right tire for your truck, you want to make sure you're getting the perfect fit for your realistic needs. An all-terrain tire is one of the best bets for those trucks that see light-to-moderate off-road use while delivering exceptional quality for your typical city and highway driving at the same time. Falken's Wild Peak A/T3W tires are one of the best options available for that cross between a quiet and smooth daily driver and the occasional romp through an off-road trail filled with mud, snow, sand or anything else you get your truck into. The LT285/70R17 Falken Wild Peak A/T3W Off-Road Tire features tough side walls and an aggressive tread pattern to give you plenty of confidence when you need to go off-road for work or play. High-Quality Construction
The LT285/70R17 Falken Wild Peak All-Terrain A/T3W tire gives you increased performance as well as longer tread-life which not only saves you money down the road but also extends your adventures. These tires feature an interlocking tread design for increased stability as well as Falken's Three Peak Mountain Snow Flake (3PMSF) symbol on the sidewall. This helps deflect rocks and eject mud when you're caught in the thick stuff. These tires strike the perfect balance between the dependability you need for rugged trails and the menacing street look you want for every day driving -- all while keeping excess tire noise to a minimum.
Tire Specs:
Tire Specs:
- Tire Diameter: 33.0
- Max Load (single): 3195 lbs.
- Tire Size: LT285/70R17
- Section Width: 11.6
- Tread Depth: 14.6
- Tread Width: 9.3
