Specs, Mods, Photos
- MODEL YEAR
- 2020
- MAKE
- FORD
- MODEL & TRIM
- Ranger Fx4
- COLOR
- Magnetic
- ENGINE
- 2.3L Ecoboost
- CAB (Supercab / Supercrew)
- Supercrew
- DRIVETRAIN (4x4 / 4x2)
- 4x4
- PACKAGES
- Fx4, Bed Utility Package, Trailer Tow Package
- FACTORY OPTIONS
- 5" Running Boards - Black
- MODS - POWERTRAIN / DRIVETRAIN
Injen PF9071WB Turbo Wrinkle Black PF Cold Air Intake;
Flowmaster FlowFX Cat-Back Exhaust System # 717909, wrapped stem to stern with 4"x 50' VViViD Black FiberGlass Exhaust Wrap;
- MODS - SUSPENSION / CHASSIS
- Completed @ Desert Rat Tucson on Palo Verde. BDS 3.5" UCA Lift Kit (3.5" Front w/ Spacers and UCA, 1" Shackle lift in rear w/ BDS Nx2 Shocks) and BDS Intrusion Beams. Installed BDS Low Profile Intrusion Beams / crash bars. Ford built the truck around the crash bars. It is a PITA to get them out. Getting shop to do this may cost $500 (mechanic $15 or $20 2 hrs labor, boss's rent, tool costs, utilities and boss's boat payment). I got mine off w/ a 5" angle grinder $130 @ Lowes. (https://www.lowes.com/pd/Kobalt-5-in-24-Volt-Max-Cordless-Angle-Grinder/1000093007) Mine came w/ weanie 2ah l-ion battery, ran down before I did. Looks like they no longer include the case, charger and battery so you would have to get them separate. Here is the 6ah battery I use - you will get tired before it runs out. (https://www.lowes.com/pd/Kobalt-24-Volt-Max-6-Amp-Hour-Lithium-Power-Tool-Battery/1000638895) and the hier watt charger so it will not take forever to charge (https://www.lowes.com/pd/Kobalt-24-Volt-Max-Power-Tool-Battery-Charger/1000604951). So $300, DIY, 2 hours. and you get to keep the tools!. Kind of a noisy process so plug your ears
- MODS - LIFT HEIGHT
- 3" Lift
- MODS - WHEELS / TIRES / BRAKES
Stock Wheels 17 x 8.0 Wheel (Offset = +55 mm - Back Space = 6.67" Inches)
Rugged Ridge 1.25” Wheel Spacers
Completed: 295/70 R17 TOYO Open Country R/T, including Bought another exact wheel and installed 5th tire on it for spare. Spare fits perfectly under the truck!. With lift Kit and BDS Intrusion Beams / Crash bars = ZERO rub scrub !
- MODS - TIRE SIZE
- 33" Tires
- MODS - EXTERIOR
- AZ Legal Window Tint
- MODS - INTERIOR
- none
- MODS - IN-CAR ELECTRONICS
- BOSS AR2000M MONO AMP, driving Pioneer TS-W254R 10" Sub in 1.9 Ft3, Ported Box tuned to 30Hz
- HISTORY, STORY, EXPERIENCE, COMMENTS
Love the truck thus far. Installed 3" FlowMaster Stainless Cat Back Exhaust myself, wrapping each piece w/ the fat fiberlgass wrap. Itchy Messy Job. The Pipes are quite touchable even right after hard drive.
Installed the Injen C/A Intake myself. Love to hear the Turbine Whine and the BlowOff Valve whoosh. On Interstate - pulls like a beast from 75mph. Gobs of torque. SUPER QUIET Cruise 65-85mph. ZERO DRONE (I suspect the fiberglass wrap actually softens the sound a bit as whatever resonance the pipes give off along the length is very blunted by the wrap.)
Strongly considering a catch can to help keep valves clean as plan to put 200k miles on this truck.
Only taken it on rough gravel / rock washed out road once. Scary Steep ups n Downs, bumps. Zero slip or slide. This with Stock Tires n Suspension. BDS Kit is installed ASAP, Tire upgrade to 295/70 R17 TOYO Open Country R/T (33.3 x 11.8. ) Looking forward to getting stuck far from help
( : o
Considering a Grill Guard
Considering a Front bumper / Winch Combo
Considering Mud Flaps (for protection against rocks)
Considering the 2020 FORD RANGER Performance CALIBRATION
