sbacpo
I'm having a BDS 3.5" lift, UCA's, Fox shocks(rear) and low profile crash bars installed as we speak. Putting Cooper STT Pro's, 285/70-17 on the stock magnetic wheels as well. Hoping I don't need spacers.
There was rubbing on the crash bar extenders. I had to pull the bumper & remove them. About a 30min job. No noticable ride difference & would do it again tomorrow, as I like the look!Sean,
I'm waiting on my 1.5" spacers to arrive. Any issues installing these. Any noticeable ride difference?
Did you get the P rated tire or the LT?I have a 3in lift with fab tech 1in spacer with 285-70-17 nitro terra grappler g2.
Have the front crashbar loosened and adjusted no rub up front. Have alittle rub
On the rear crashbar do to the weather tech mudguard covering the rear crash bar. Gonna do a mod to the mudguard the should take care of the rub.
Quick question -- where did you get the 1/4" spacers? (can you share a link?) I've been looking for mine....Factory 17 inch magnetic rims
3 inch ready lift leveling kit
285/70r17 Ridge Grapplers
1/4 inch spacers in the front.
No rubbing. Quiet ride. Love the look!!!@
P the 116 tDid you get the P rated tire or the LT?
Not sure. The guy I brought it to found themQuick question -- where did you get the 1/4" spacers? (can you share a link?) I've been looking for mine....
Beautiful....what spacers did you use?I have a 3in lift with fab tech 1in spacer with 285-70-17 nitro terra grappler g2.
*Edit - n/m, when I first read I thought the 1" fabtech was an additional lift...[/Q
If you're rubbing the front crash bar(s), you may want to check to see if they were installed a bit crooked. My driver's side was and rubbed with the same sized tires as you. Get a 15mm" crescent wrench and loosen the top bolts holding the crash bar in, then get a large flat head screw driver and lever the crash bar forward a bit in the frame, then tighten the bolts. Stopped all the rubbing for me. I was amazed at how far forward the crash bars moved.Beautiful....what spacers did you use?
Brad, I too used your build as inspiration, thanks for sharing, I'm very happy with the end product.Factory 17 inch magnetic rims
