joeb427
- Thread starter
- #1
Any front blinker LED replacement out there that is a simple plug and play?
the ones I installed hyperblink too. I’m going to get forscan to disable it.I swapped mine out to LEDs as well. Tried them out before I installed the resistors. They hyperblink inside the cab, but the lights themselves still blink at the normal speed. So it all depends if you care about hearing the quick tone or not. The LED turns and matching resistors from Diode Dynamics (where I got mine) was worth it for me.
What was the wire colors for the wires you connected the resisters to? I installed the Diode Dynamics resisters but either I connected to the wrong wire, are the connection is bad because its still hyper blinking.I swapped mine out to LEDs as well. Tried them out before I installed the resistors. They hyperblink inside the cab, but the lights themselves still blink at the normal speed. So it all depends if you care about hearing the quick tone or not. The LED turns and matching resistors from Diode Dynamics (where I got mine) was worth it for me.
Well, the sun is yellow, it heats the ground, that's how they name stuff. hahaWhat was the wire colors for the wires you connected the resisters to? I installed the Diode Dynamics resisters but either I connected to the wrong wire, are the connection is bad because its still hyper blinking.
