Rene Michaels
Beat this one ...a Ford Pass app that has a tire pressure gauge with a message that reads "Do not use as a tire pressure gauge"
Honestly, you're not supposed to use any TPMS as a replacement for physically checking the tire pressure with an actual gauge. It's always been that way.Beat this one ...a Ford Pass app that has a tire pressure gauge with a message that reads "Do not use as a tire pressure gauge"
Agreed, but why bother putting it on the app if it's useless?Honestly, you're not supposed to use any TPMS as a replacement for physically checking the tire pressure with an actual gauge. It's always been that way.
Its not useless.. it tells you the tire pressure. You are confusing definitions of legal obligations from an automaker and common sense. If you get out a pressure gauge and check the pressure guess what.. it says the same thing. Its a convenience more than anything to know if you have a flat tire before get to the truck. I was able to tell when the tire shop was changing my tires because I watched the psi from the app.Agreed, but why bother putting it on the app if it's useless?
Completely agree, some people are not capable of comprehending tire pressure in any capacity. However, I use the tire pressure gauge in the truck to see what my tires are at when off road. Cold mornings ill have 19 psi and mid day it can get over 25 and ill use that to decide when i need to air up or down dependent on the terrain. Its a huge bonus for my use case.There are some instances where it's not correct. That's all I'm saying. To me, the reason TPMS exist is the same reason "idiot lights" exist on modern cars. Without them, people would have no clue what's going on with their vehicles since they won't exercise a single bit of maintenance initiative.
This is off-road driving only? I've never had that much change in tire pressure with extended highway driving!Completely agree, some people are not capable of comprehending tire pressure in any capacity. However, I use the tire pressure gauge in the truck to see what my tires are at when off road. Cold mornings ill have 19 psi and mid day it can get over 25 and ill use that to decide when i need to air up or down dependent on the terrain. Its a huge bonus for my use case.
Yeah in elevations from 12,000 down to 6,000 it will fluctuate a lot. Some tires that are exposed to the sun will be in larger differences where the side without sun will be cold still. Temps range from 30-40 in the summer at night to mid 80s-90s in the day. Combine all of it and it makes for a wide range of tire pressures throughout a trip.This is off-road driving only? I've never had that much change in tire pressure with extended highway driving!
Of course, why would you use the Tire Pressure Monitoring System to monitor tire pressure, you'd have to be some kind of crazy person.Honestly, you're not supposed to use any TPMS as a replacement for physically checking the tire pressure with an actual gauge. It's always been that way.
Sarcasm aside, I'm fairly certain you're completely able to understand exactly what I'm talking about.Of course, why would you use the Tire Pressure Monitoring System to monitor tire pressure, you'd have to be some kind of crazy person.
